Cocobolo/Adi Dreadnought
Post by Bob Connor » Sun Jan 04, 2009 1:01 pm
I thought I'd detail the construction of this instrument so it's owner can keep track of it's progress and I can make some notes on how the Coco works.
Both the top (Adirondack Spruce) and the back and sides (Venezuelan Cocobolo) came from Bob Cefalu at RCTonewoods.
You can see that the Adi top has lots of late growth in it (the dark stripes) which makes it extremely stiff. It also makes it a lot denser and heavier.
There is up to 120 grams difference between some of the Adi tops I have.
The top was joined using a Jet jointer. I then put some 3M Stickit sandpaper on to the bed of the jointer and make a couple of passes of the top on the sandpaper (which generally ensures a tight joint)
The Cocobolo is extremely oily and will clog up the paper on your drum sander in no time at all.
I keep a roll of 40 grit paper just for jobs like this. It will get your wood down to thickness reasonably quickly without clogging up like 80 grit does.
In this case I was thicknessing the sides which I wanted to end up at .080". I took them down to .095" with the 40 grit and then swapped to the 80 grit to end up with the dimensions that I wanted (which ended up around .081"-.082")
I then sanded with the random orbital with 120 grit before bending.
I used my now standard procedure for side bending, which is to sandwich the sides firstly in kraft paper, the spritz lightly with water and then wrap in aluminium foil.
Then heat the sides in the Fox bender, starting the lower bout bend when the temperature hits 100c. Then do the upper bout and finally screw it all down. Watching the thermometer allow it to reach 150c and them turn it off and allow to cool.
This Coco bent easily with very little springback.
The next step is glueing in the neck and tail blocks. We used to do this in the mold but it proved problematic so we now do it before insering the sides into the mold.
So far I've had no reaction to the Cocobolo.
Thanks fer lookin'. To be continued
Post by ozziebluesman » Sun Jan 04, 2009 6:04 pm
G'day Bob.
Looking forward to watching this one grow. I am keen to see how the Cocobolo behaves! This post will be useful for me later on when I use my set of Coco.
Post by Allen » Sun Jan 04, 2009 6:21 pm
I've heard some people have experienced problems with glueing Cocobolo. Ire you doing anything special to deal with this possibility?
Post by Bob Connor » Sun Jan 04, 2009 6:27 pm
Next we need to put the sides into the mold and shape both the back and top with 15" radius for the back and 25" radius for the top.
We converted an old potters wheel.
The next step is to flatten the upper bout so that the 2 degree neck angle fits properly and there's no 14th fret hump.
I built this jig to do the job. the tail block sits on a piece of wood 1/8" thick.
The next step is to install some cloth strips on the guitar sides to prevent the spreading of cracks in the event that the guitar gets a knock on the side. I haven't got the strips yet so I'll make the kerfed linings ready to be installed over the cloth strips.
This is a simple jig the sits on our small bandsaw. The depth of the kerf is varied by by adjust the upper blade guides back or forward and the cut is done by aligning the pencil mark up the the jig by eye. ie no indexing pin.
Post by Hesh1956 » Sun Jan 04, 2009 11:55 pm
Great looking guitar Bob my friend. That coco is beautiful!
When are you going to clean that shop - must be hard to find Le Fridge in there..... :D
Post by Mark McLean » Mon Jan 05, 2009 6:42 am
Cocobolo makes me cry!
Yes, because it is beautiful, but also because I got some dust in my eye last week and I had raccoon eyes for 7 days. Needed steroid drops to get it to settle down. I used it last year without any problems but the sensitivity can develop late - so take care. But those sides are stunning!
Post by Bob Connor » Mon Jan 05, 2009 8:15 am
I'm going to use epoxy to join the back plates.
Hippety Hop
Post by Hippety Hop » Mon Jan 05, 2009 9:39 am
Good stuff. I like that idea of flattening the upper bout after radiusing.
Cocobolo looks good. Anyone tried it for fretboards?
Hippus Erectus
Post by Bob Connor » Mon Jan 05, 2009 10:33 am
This ones going to have a Coco fretboard Hip
Post by Kim » Mon Jan 05, 2009 4:41 pm
Sexy coco Bob, did you pick that set out urself when you visted BobC??
Post by Bob Connor » Mon Jan 05, 2009 5:08 pm
Kim wrote:Sexy coco Bob, did you pick that set out urself when you visted BobC??
Sure did.
Post by Bob Connor » Mon Jan 05, 2009 5:43 pm
Today I took myself down to the local haberdashery shop to buy some bias binding. This is for reinforcing along the guitar sides to stop any cracks spreading further that they should.
Previously I've used wooden ones or in small instruments none at all but I thought I'd give the cloth a go considering that it doesn't weigh too much and the fact that the Cocobolo is bloody heavy.
Next I throw the kerfed linings into the Fox bender not so much as to bend them but to heat them up and make them pliable. They'll get a spritz of water before they go in.
Once they're cooked ( I'll start bending them at 80 C and once the bend is completed turn the blanket off and leave for about 5 minutes.
While they're still warm I'll dry clamp them into the sides so they'll conform perfectly and also to allow them to dry out completely. (We've glued them before when they were still damp and the glue joint came apart.)
Once they're dry we'll glue them with Titebond and clamp.
While all of this was going on the back plates were joined.
I took the liberty of throwing in a piece of decorative backstrip.
Allan, who'll be the new owner of this weapon was admiring a similar one in my Hondo Rosewood OM, plus I thought it may be better to glue the Coco to the Maple backstrip rather than Coco to Coco given the problems that a lot over people having glueing this wood.
I didn't wipe the joint with acetone or anything. Just glued the two back plates as soon as the joint had been done on the jointer.
Things may slow down a bit now as I'm waiting on a piece of Cocobolo for the rosette fro Uncle Bob. I've got one here but it's warped and I'm sure it'll crack if I try and do anything with it.
Post by Hesh1956 » Tue Jan 06, 2009 12:35 am
When are you going to clean that shop - must be hard to find Le Fridge in there..... :D :D
Post by Bob Connor » Tue Jan 06, 2009 7:21 am
The shop has that "lived in " look at the moment.
Never fear Hesh. Le Fridge is always accessible. :D
Post by sebastiaan56 » Tue Jan 06, 2009 8:22 am
Hesh,
That is a clean shop..... by my standards anyway...
Looks nice Bob, does Cocobolo have any sonic properties to compliment the bling factor? It sure is pretty,
Post by Bob Connor » Tue Jan 06, 2009 8:39 am
Sebastiaan
Cocobolo has that typical glassy Rosewood ring that has long been associated with Brazilian Rosewood.
A lot of builders believe that it and Honduran Rosewood are drop in replacements for Brazilian.
Unfortunately both Cocobolo and Honduran Rosewood are likely candidates to get CITES appendix II listings in the near future.
They already have Cites III listing as one country (Guatemala) has asked for assistance in controlling the trade of that species.
There's a full listing here.
CITES appendices
Post by DarwinStrings » Tue Jan 06, 2009 12:19 pm
You are prolific Bob and you manage a full time job as well, I'm surprised you even get time to drink beer. The old potters wheel is a interesting contraption, I saw the pic before I read your text and thought you'd been putting you guitars in a washing machine. I would like to know where you got those small colourful clamps as I can't find any like them and would like to add a few handfuls of them to my kit.
This forum doesn't like the way I spell colour, I refuse to comply.
Post by Taffy Evans » Tue Jan 06, 2009 12:46 pm
Thanks for the progress reports, what can I say. When one gets in late it's all been said, I agree with all the other viewers, great stuff.
Jim...I got two buckets of those clamps [they came in plastic ice creem type buckets] from bunnings.
Post by DarwinStrings » Tue Jan 06, 2009 1:15 pm
Thanks Taffy
I might have to take Bob's pic into Bunnings and do a "special order" ( that means a order that takes a month then gets sent to the wrong store ) as I have never seen them here, I have a stack of larger peg type from Bunnings but those small ones look handy.
Post by Lillian » Tue Jan 06, 2009 1:24 pm
Jim, Bob does some amazing things, no doubt about it. But just so you know, he has a silent partner, Dave. I have seen pictures that Bob has identified the individual as Dave, but I don't know if Dave has ever posted to the forum, hence the silent, if so it was a long long time ago and I have slept since then.
Post by Bob Connor » Tue Jan 06, 2009 5:51 pm
Funny you mention it Lillian but Dave was in the shed today so I got photographic evidence. He's been busy with other things the past three or four months so I've been flying solo up until now.
We've got quite a few instruments to finish before the Port fairy Folk Festival.
Post by Bob Connor » Tue Jan 06, 2009 6:04 pm
I took the back out of the clamps this morning and thicknessed it down to .090"
Then marked out the back brace positions. I know the bottom one looks way off but it's where I picked up one of the back braces and the chalk came off it.
Radiused the back braces to 15". These are Engelmann Spruce and I cut most of the radius with the bandsaw before using the radius dish. The braces are 8mm wide. On smaller guitars I use 6mm.
I scallop out the ends of the back braces on the belt sander before glueing.
I used Hot Hide Glue for the back braces on this one. Normally I'd use Titebond but I thought I'd see how the HHG goes with Coco.
matthew
Post by matthew » Tue Jan 06, 2009 6:45 pm
Loving watching this in real time Bob.
Funny, the thought of starting a guitar fills me with trepidation. Your posts make it easier to contemplate.
Post by Hesh1956 » Wed Jan 07, 2009 3:10 am
Bob my friend Dave looks like he is enjoying himself.
Has Dave ever posted on the ANZLF? If not perhaps you could get him to drop in and at least tell me to piss off? :D
gratay
Post by gratay » Wed Jan 07, 2009 8:52 am
thanks, I'll be watching with great interest..
Cocobolo is so stunning...I think with a cocobolo fingerboard that will be a real looker.
Users browsing this forum: Google and 114 guests
