French Polishing Engleman
I started French Polishing the Engleman top (Grahams 3A grade) on a classical the other day. I sanded back to 320 grit with garnet paper and then did a couple of wetting sessions to raise the grain and then sanded back again.
Once Id got the seal coats on I noticed tiny pin holes breaking through the shellac. I took a closer look with a Lupe and it looked very much like the grain was raising again under the shellac and some of the nibs were protruding through the finish. I let the shellac harden and then sanded back with oil lube using 400 grit wet and dry. After two body sessions theres no sign of the surface breaking up and all seems ok.
Anyone had this experience with Engleman?
Thats a great help Allen....looks like my thoughts were on the right tracl. useful information for others FP'ing Engleman. Havent had the problem with Sitka or Lutz.
Allen wrote:Never French Polished it Martin, but I have noticed it being a little furry sometimes when I spay the first coats of lacquer. I put the first few coats on piss thin, then give them a little tickle with some P400. Seems to fix the problem.
- Hippety Hop
Fill the pores in a spruce?
You'll always get a bit of fuzz and such on the first coats of anything.
Romanillos uses a ground of egg white as a sealer on wood before French polishing. Egg white brushed on, allowed to dry, and then sanded lightly...
I like "Waterlox"...a very thin tung oil "long oil" varnish...as a presealer under just about anything.
Rick Turner
www.renaissanceguitars.com
www.d-tar.com
www.d-tar.com
Dunno why I didnt think of that...I used the technique while doing some practise work on a dummy top last year.Rick Turner wrote:
Got two more body sessions done yesterday and the top is looking good now. Thanks for everyones help/comments.
Cheers Martin
Users browsing this forum: No registered users and 77 guests
