Curved Radius Templates
Kim Strode
Post by Kim Strode » Thu Nov 22, 2007 4:38 pm
I am looking for a source of radius outlines or templates, so I can make my own radius dishes on a lathe. Particularly 30' radius and upwards. Does anyone have a link?
Post by Allen » Thu Nov 22, 2007 5:52 pm
I made my own by using a long tape measure with a pencil at the desired mark and tracing an arc. Very easy to do and cheap.
Post by Hesh1956 » Fri Nov 23, 2007 1:14 am
I need a set too and found these from Tracy at Luthier's Suppliers.
[url]http://www.luthiersuppliers.com/products/p7.html[url]
Post by Hesh1956 » Fri Nov 23, 2007 1:15 am
graham mcdonald
Post by graham mcdonald » Fri Nov 23, 2007 8:52 am
There is (or used to be) a pdf on the MIMF site (in the library) of a whole range of radius outlines. If you can't find it I have it on the 'puter at home and I can send it to you.
I have been building radius workboards using John Calkin's method of radial spokes cut to the necessary shape glued to an MDF or ply base with a top of 3mm masonite or MDF just glued on (written a few years ago in American Lutherie. A simple a cheap method for those of us without a lathe. I can post some instructions if anyone wants them
graham
Graham McDonald
Kim Strode
Post by Kim Strode » Fri Nov 23, 2007 10:01 am
I would really appreciate it Graham if you could post instructions for your 'radial spokes' method of making workboards. Thanks
graham mcdonald
Post by graham mcdonald » Sat Nov 24, 2007 7:38 am
I have put a brief tutorial on building dished workboards in the Tutorial section
graham
Graham McDonald
matthew
Post by matthew » Sat Nov 24, 2007 7:06 pm
Somewhere, I read of someone doing this by suspending a router(!!) from the shed ceiling, putting the MDF blank on the floor and playing pendulums...
BillyT
Post by BillyT » Sat Nov 24, 2007 8:38 pm
30' Shed??
Woah! That's a pretty big shed! Maybe a Barn!
Here's a link posted by Klepper on the OLF to a method of making any radius you'd like by using 2 pins and two long pieces of wood!
Long Compass
All one needs is the chordal height for the distance between the pins!
