Progress on an 0-18
Progress on an 0-18
Post by Bob Connor » Mon Nov 08, 2010 12:15 pm
"Originally Posted on:"Tue Aug 10, 2010
Starting to get to the pointy end of this one. It's Lutz Spruce from Shane Neifer on Honduran Rosewood back and sides with Cocobolo bindings. Ebony fingerboard and Braz bridge.
seeaxe
Re: Progress on an 0-18
Post by seeaxe » Mon Nov 08, 2010 12:18 pm
Very Tasty! Love the shape and the wood combinations.
Localele
Moderator
Post by Localele » Mon Nov 08, 2010 12:19 pm
What neck joint Bob?Dovetail or bolt on M&T?
Cheers from Micheal.
Remember the "5P Rule".
rye_bear
Post by rye_bear » Mon Nov 08, 2010 12:19 pm
Hi bob, i was just wondering what size your your lower x brace is at is largest point? (the one that is right under the bridge plate also what is your upper x brace size?
Also how is your end block glued up? is it just face glued onto end grain?
or is it solid?
thanks.
Rye.
Post by Bob Connor » Mon Nov 08, 2010 12:21 pm
The neck joint is a butt joint Michael. the neck is solid one piece with an extension that fits in the body cavity.
I've taken to inserting stainless rods and hex screws in the heel to attach the neck.
Rye - those lower X braces are very small - 3mm x 5mm - being a lattice they don't need to be very big to be strong.
The main X Brace is 13mm x 6mm.
Thanks for looking
Localele
Moderator
Post by Localele » Mon Nov 08, 2010 12:21 pm
Will you use a screw to help hold the extension to the soundboard so it isn't floating.SS is always a good thing.
ON another topic , how goes the Mac?
Post by Bob Connor » Mon Nov 08, 2010 12:22 pm
No screw. The extension just sits in the pocket.
Mac is going fine. I'm just trying to find applications that'll replace what I was doing on PC. Backlit LED screen is great.
Post by Nick » Mon Nov 08, 2010 12:26 pm
Sharp as ever Bob & that bracing looks cleaner than a clean thing. It's gonna sure look purdy when it's done.
Post by Kim » Mon Nov 08, 2010 12:27 pm
Yeah she's a beauty Bob, can't wait for a sound report...and those inserts you had made up are veeery znazzzie. 8)
Post by Craig » Mon Nov 08, 2010 12:27 pm
Likewise ..
I'm impressed with the hardware . Getting those two threads lined up in the round stainless ain't easy. Nice work on the bracing and soundboard design too Bob.
Honduran Rosewood and Lutz just has to be a winner
Craig Lawrence
Post by Lillian » Mon Nov 08, 2010 12:28 pm
Your execution is flawless as usually. And like the rest of the mob, I look forward to your report and a maybe a sound clip?
Bob, did you have the stainless insert machined for you or are you tapping them yourself?
Post by Bob Connor » Mon Nov 08, 2010 12:28 pm
Thanks everyone.
Lillian - I get the bass player in my band, Rick to machine them for me.
christian
Post by christian » Mon Nov 08, 2010 12:29 pm
Wow Bob that guitar is looking very sharp.
very nice bracing on the top its gonna sing!!!!
look forward to seeing it finished.
great work !!!
Christian.
Leonardo da Vinci
www.christiandruery.com
Post by DarwinStrings » Mon Nov 08, 2010 12:29 pm
Nice work Bob, what can I say, bolt on neck.
I like the headstock and the way the tuner holes get closer towards the top of the head as I assume the strings travel over the nut straighter than a Martin style head.
Luke
Post by Luke » Mon Nov 08, 2010 12:30 pm
I like the nifty neck joint Bob, did you have to make up longer truss rods?
Cheers Luke
liam_fnq
Post by liam_fnq » Mon Nov 08, 2010 12:30 pm
very neat and tidy bob, your usual modus operandi.
I recently got to have a look and a tap on some Honduran Rosewood sets. The sustain from a light tap would put a horn on a jellyfish.
Post by Bob Connor » Mon Nov 08, 2010 12:31 pm
Honduran Rosewood is one of my favourites Liam.
Unfortunately it's already appendix 3 listed on CITES so it's just a matter of time before it gets listed on appendix 2 and becomes difficult to get across borders.
Grab some while you still can.
Cocobolo is in the same boat.
Roger that. Preparing credit card for lift off :twisted:
