reamers
vandenboom
reamers
Post by vandenboom » Tue Nov 16, 2010 9:24 pm
When periodically perusing the stewmac/lmi's catalogues, I always stop when I see reamers for bridge pin holes & machine head holes. I want them to improve quality but find them expensive for what they do, given that I think I'm getting by with drill bits and a cheap reamer from Total Tools. I must admit that the cheap reamer doesn't always produce a true circular hole.
Do any of you have other techniques for reaming, even if they take a bit more time?
Frank
Re: reamers
Post by Bob Connor » Tue Nov 16, 2010 9:27 pm
The Stewmac reamers are a good bit of kit Frank, and definitely worth the money.
Re: reamers
Post by Allen » Wed Nov 17, 2010 6:40 am
I've got a couple of good reamers from Snap-On but they didn't make a perfect tapered hole either. I then got the Stew Mac 3 degee and don't regret it. They are very sharp and cut a perfect taper.
P Bill
Re: reamers
Post by P Bill » Wed Nov 17, 2010 8:35 am
You can make a peg taper to match the reamer .It's just a large pencil sharpener similar to stewmac's peg taper. No photos I can't find mine.
Bore a hole in a hardwood,ream it and expose the reamed taper just enough to see the peg. Screw or clamp a plane iron at the edge of the taper, adjust as needed. Use a sanding block to polish the peg.
I like the look of pegs on Flamincos and Benedetto's nylon string.
Re: reamers
Post by kiwigeo » Wed Nov 17, 2010 11:38 am
The best reamer.....my wife :mrgreen:
Re: reamers
Post by jeffhigh » Wed Nov 17, 2010 12:14 pm
The Stewmac tuner bushing reamers are really worth having, give a nice clean concentric hole sized right for the bushing.
