Pristine 1941 Martin 000-18 on ebay
morgan
Post by morgan » Sat Nov 20, 2010 6:54 am
So many beautiful shots of this guitar (interior and exterior) I was almost tempted to post this in the gallery section :-)
Looks in amazingly good condition.
http://cgi.ebay.com/1941-CF-Martin-Co-0 ... 336294d8c0
morgan
Re: Pristine 1941 Martin 000-18 on ebay
Post by morgan » Sat Nov 20, 2010 8:17 am
Looking at the interior shots of this Martin made me curious about some of it's construction. Does anybody here know what's going on with the sides? It looks like there are vertical strips of fabric tape(?) stuck along it at various points. What are these and what is their purpose?
Post by Bob Connor » Sat Nov 20, 2010 8:24 am
Side reinforcements.
They will stop a crack from spreading if the instrument gets a hit on the side.
Fabric is easy to install and very light in weight. Can be stuck with water down hide glue or Titebond
A lot of people us wooden side re-inforcements but unless you tuck them into your kerfed linings they can leave a stress riser right at the edge of the kerfed lining. This may lead to a more difficult repair if you get a knock in that area.
The cloth reinforcements extend to the edge of the side under the kerfed lings so you don't have to bother notching them in.
Myself - I use laminated sides so I don't have to bother with them.
Sensational looking 000 for it's age.
John Maddison
Post by John Maddison » Mon Nov 22, 2010 12:44 am
Truly a nicely made guitar, probably worth every penny of the $7k+ asking price, and some amazingly crisp images of same (esp. the interior).
I have a question that has lingered for a long time re the orientation of two bookmatched boards that make up a top; in one image of this Martin it is clear that the grain lines are WIDER apart near the join and DIMINISH in distance apart as the lines progress towards the edge of the instrument
I've always believed it's better to join two pieces of matching soundboard with the closer grain lines at the join; in the image above it's the exact opposite. In a recent baritone uke build I 'accidently' glued the two boards with wider grain lines at the join, but have kept the top in the hope that it'll still work fine - looking at the Martin build technique I'm now not so bothered.
Are there any hard-and-fast rules re: grain lines on joining two top boards that should apply for optimum acoustic tonality?
John M
Post by Kim » Mon Nov 22, 2010 9:13 pm
John, if there are incursions such as knots or localized runout on the finer edge near the bark, then they would joint toward the heart so they could use the wood.
Post by Allen » Tue Nov 23, 2010 7:26 am
I think you'd need to assess each piece of wood on it's own merits. If the wood is equally stiff across the width and it's equally on, or for that matter off the 1/4, then it's just a matter of aesthetics.
Post by Bob Connor » Tue Nov 23, 2010 8:09 am
If the late grain lines are wider apart at the perimeter it MAY mean the the top is more flexible in that area and thus more desirable. (same sort of thing as thinning the perimeter to make it more flexible)
John Maddison
Post by John Maddison » Tue Nov 23, 2010 9:22 am
Thanks fellas ... all very useful and sound advice :cl.
John M
Users browsing this forum: Google and 24 guests
