Pearl Hide Glue - Laminated Sides
- Kim Strode
I've been looking at http://www.ukuleleunderground.com while researching information to build a Cavaquinho. I came across a post on laminating Ukulele sides. On this thread I noticed mention of a Pearl Hide Glue recommended for gluing veneer. It occurred to me it could be of interest to others. Find the glue at http://www.leevalley.com/en/wood/pag...110,42965&ap=1
This is the link to laminating Ukulele sides - http://www.ukuleleunderground.com/forum ... -Uke/page1
Kim Strode
Daylesford, Australia
Re: Pearl Hide Glue - Laminated Sides
Have built a tenor uke using a double rib. We used titebond to laminate a 1mm piece of pecan to a 1mm rib of cottnwood. The density of our pecan here is about the same as e indian rosewood and the cotttonwood is soft as spruce. I have found that this laminate makes an extremely stiff side without a lot of extra weight. I would be hesitant to use hide glue, in our cold climate, as it would set before we had a chance to rollout the titebond glue and laminate the 2 rib pieces in a mold. M cheers , hope this helps ernie
Welcome to the forum Ernie. That's a great selection of videos you have posted. Great resource for people. Thanks for taking the time.
Further to Kim's initial post, I'm just in the process of building some laminated sides for a uke. Used 312 hot hide glue and everything worked a treat. Though my conditions are probably a bit more favourable to open time as it was 43 degrees in the shed when I was doing it.
- matthew
if you use a silicone heat blanket for bending you can lay up laminated sides primed with HHG and use the heat blanket in the press to re-heat and fuse the hide glue between the laminates. "open" time is therefore not a problem. I have done this successfully on a 9" wide bass rib.
matthew... Did you lam. to make the rib thicker than normal or because of a difficult bend ? DB ribs seem way to thin to survive anything but the most careful treatment. Good technique by the way.
- matthew
Bill, I read about that technique, and a iColleague in USA had done it, so it was a test to see if I could do it. I could.
mt
mt
Yes Ernie, it's summer and in the very wet tropics of Northern Australia. though winters aren't all that much cooler but usually drier than we've had of late.
Hey Ernie ... you made the first post of 2011.
Simon
Simon
- matthew
as I said, it was only a test on one rib. I used silver ash on the inside and silky oak on the outside. The grain in both pieces ran parallel. 2.5mm was final thickness I think. Temp was done in two stages, I bent the laminations in a sandwich first (hot) onto the mould, then I opened it up, primed with HHG and before it got too dry I re-made the sandwich and bent again (not so hot)ernie wrote:Thanks to all who shared. Matthew, I/m curious . I have a DB in the works, was planning to use1/8 in or 3 mm baltic(russian) birch plywood for db ribs. When you did the double lamination for the db ribs on the heating blanket.How thick were each of the 9 in ribs, what species were you using, and at what temp?? thanks ernie
MT
Users browsing this forum: No registered users and 226 guests
