My drill press won't press !
Dave Anderson
Post by Dave Anderson » Fri Dec 21, 2007 12:32 am
Hi Fellas,
I'm hoping someone out there has had a similar problem and can help.
My drill press (Delta DP-400) will not shut off when I shut it off.
It just wants to keep working! I ordered a new switch and it still won't stop!
It's a pain having to unplug it all the time.
Anybody had a problem like this with your Delta :?: Thanks...Dave
Dave Anderson
Port Richey,Florida
Ron Wisdom
Post by Ron Wisdom » Fri Dec 21, 2007 2:18 am
That's weird that a new switch didn't work, it must be possessed. :twisted:
The only thing I can think of is it must be shorting somewhere. Check as much wiring as you can get to for a bare spot. Juice has to be bypassing the switch somewhere, I'd think.
Ron
Post by kiwigeo » Fri Dec 21, 2007 3:07 am
Try unloading two barrels of buckshot into the machine :D
Paul B
Post by Paul B » Fri Dec 21, 2007 10:51 am
The switch must be wired wrong or shorting out. Otherwise there wouldn't be any juice getting to the motor, if there's a short somewhere it's gotta be at or before the switch.
Dave Anderson
Post by Dave Anderson » Fri Dec 21, 2007 12:18 pm
I just went out and tried it with the switch unconnected and it still ran!
I have to have a short somewhere.
Thanks guys!!
Dave Anderson
Port Richey,Florida
