Help needed with recent build
- Tod Gilding
I have just finished my latest build but it doesnt play all that well,and I'm not sure what I did wrong, Any idea's ?
- biggit_29744714_std.jpg (12.12 KiB) Viewed 23999 times
- J.F. Custom
Re: Help needed with recent build
Intonation? I'm thinking that 8th fret looks a few thou out...
Are those the strings you used for setting up the nut? You really ought to change them.
It seems that limited storage space was a major concern when designing this axe and therefore you kept the sides a bit shallow. So the air resonance might be a bit too high.
Nice guitar though. Is it foldable?
Try shifting the string spacing a little closer or dropping two strings altogether, buy a sombrero & turn it into one of those big arse mexican basses. You'd make a fortune at outdoor resturantsTod Gilding wrote:I have just finished my latest build but it doesnt play all that well,and I'm not sure what I did wrong, Any idea's ?
- Tod Gilding
Thanks Jeremy, I just Checked that 8th fret, I use my fingers for that, I know that from the tip of my index finger to the first knuckle is the first fret,then it's just a matter of adding a little bit for each fret after that,I find this method very accurate,and the 8th seems more or less right.Intonation? I'm thinking that 8th fret looks a few thou out
- sebastiaan56
Well you've settled the discussion on who's is biggest...
- Tod Gilding
Lillian, Down here we have a supplier of high quality strings, we call it the Hills Hoist.Are those the strings you used for setting up the nut? You really ought to change them.
Tod, I'm familiar with those. I know our local supplier carries coated wire and filament. I find that they tend to be a bit stretchy. Hard to get broken in properly.
Assuming that's a normal size guitar I'd say you need to offer it to someone who isn't a garden gnome.
TeeHeeHeeeliam_fnq wrote:Assuming that's a normal size guitar I'd say you need to offer it to someone who isn't a garden gnome.
- Tod Gilding
I Don't Get It ????? Whadda ya meen ????Assuming that's a normal size guitar I'd say you need to offer it to someone who isn't a garden gnome.
- Tod Gilding
Ya Gotta Love April fools day, If it was any other day, the Mods would be chasing me with a heavy neck blank
- Mike Thomas
[/quote]
I suspect that this is where your problem may lie. No guarantees of course, but it could be worth "taking a little bit off for each fret after that".
Mike Thomas
- Taffy Evans
I think the problem would mainly be with bar chords, otherwise it should play in tune. Do you get help to turn the tuners?
Mike Thomas wrote:Thanks Jeremy, I just Checked that 8th fret, I use my fingers for that, I know that from the tip of my index finger to the first knuckle is the first fret,then it's just a matter of adding a little bit for each fret after that,I find this method very accurate,and the 8th seems more or less right.
I'd say you'll get a better result by taking a little off each knuckle after that.
- Tod Gilding
Bugger , Your Right, i was thinking it strange, that I could play the 12th fret with with the palm of my hand.
Hot chili peppers in the blistering sunNick wrote:Try shifting the string spacing a little closer or dropping two strings altogether, buy a sombrero & turn it into one of those big arse mexican basses. You'd make a fortune at outdoor resturantsTod Gilding wrote:I have just finished my latest build but it doesnt play all that well,and I'm not sure what I did wrong, Any idea's ?
- matthew
Looks kind of normal to me. I don't see what the fuss is about. But why are you holding it sideways?
You guys...its not a real guitar, its a giant cardboard cut out!!!!
Don't be silly Martin. What would a garden gnome be doing with a pair of scissors??kiwigeo wrote:You guys...its not a real guitar, its a giant cardboard cut out!!!!
Kim wrote:Don't be silly Martin. What would a garden gnome be doing with a pair of scissors??kiwigeo wrote:You guys...its not a real guitar, its a giant cardboard cut out!!!!
you don't get a beard like that by having a pair of scissors floating around
It's Grizzly Adams. Poor ol' Grizzly doesnt have any money so he cant afford to buy a real guitar.
My point exactly.liam_fnq wrote:Kim wrote:Don't be silly Martin. What would a garden gnome be doing with a pair of scissors??kiwigeo wrote:You guys...its not a real guitar, its a giant cardboard cut out!!!!
