Evening All
I am thinking about building a classical guitar. I have a number of options to choose from and was wondering what combinations you guys thought would be best
ATM I have in the mini stash
Tops
Englemann
Lutz
WRC
Back and sides
Iroko
Brazilian Mahogany
Kwila
Any thoughts about what goes with what, tone wise?
Or should I get some more EIR?
And whose plan is best???
Grateful for your thoughts though, sadly, I have no tubs of yak fat to offer in return
Classical Build
Classical Build
Re: Classical Build
Tops
Englemann
Lutz
WRC
Back and sides
Iroko
Brazilian Mahogany
Kwila
1. All three top woods in you list will go well on a classical. My choice in order of preference in terms of sound would be Lutz..Englemann..WRC.
2. My choice for back and sides...blackwood.
3. Which plan is best? If its your first classical then Id keep it simple and follow a Torres style plan.
Cheers Martin
Re: Classical Build
Thanks Martin
The vast majority of respondents have recommended that option, so I shall go with it!
By chance the Lutz came with the blackwoood, so that was obviously meant to be.
And I had already decided on the Torres plan - it looks symmetrical so can change to a righty when it needs to.
- Kim Strode
Re: Classical Build
Question for Martin:
I noticed you listed your 3 preferred woods for Classical Tops. As I have only built a classical with a WRC top and was very pleased, can you best describe your preferences for your order of choice..."My choice in order of preference in terms of sound would be Lutz..Englemann..WRC."
Kim Strode
Daylesford, Australia
Re: Classical Build
Hi Kim,Kim Strode wrote:Question for Martin:
The choice is to some degree personal taste. I like Lutz because it's light and stiff. It's also easy to work with. Englemann is more prone to denting and scratching while you're working with it. It's also a bit fuzzy when it comes to finishing the guitar....Ive had issues with nibs sticking through the french polish even after sizing with egg whites followed by sanding down to 320grit sand paper. Sound wise the Englemann can take a while to "play in" where as with the Lutz and WRC the guitar finds its voice alot quicker. Ive built two classicals with Sitka Spruce and they sound good...sitka is an easy wood to work with and good for beginners.
- Kim Strode
Users browsing this forum: No registered users and 190 guests
