I built a Weissenborn last month that ended up with a twist in the neck. One side of the nut was about 1/4 of an inch higher.
So I thought I'd strengthen up the neck joint from what I had been previously been doing.
The original joints were as shown below, with spruce stiffeners in the neck.
I decided to extend the stiffenners and incorporate them into the headstock to give it a bit more strength.
It seems to have worked. The last two weissys have been flat as a tack. I'm not really sure why the other one warped. Probably a cranky piece of timber that wanted to move but I thought I'd share what I consider to be an improvement in the original design.
A different take on the Weissenborn neck joint
Re: A different take on the Weissenborn neck joint
I don't know anything about Weissenborns but your new solution makes perfect sense to me. Stronger, more stable and it seems to me that it's even easier to install and align.
Last edited by charangohabsburg on Sun May 15, 2011 7:29 am, edited 1 time in total.
- Dave White
I used cf bars in the last one I made (similar in principle to the flying buttress braces I use in my guitars):
I use this system in hollow arm harp guitars too:
Dave White
This is funny timing Bob, I was talking to a young engineering student on Friday who was into building Weezy's & he wanted to have a look around my 'shop', he bought his rather nice teardrop shaped Weezy with him (it was the first Weezy I've seen 'in the flesh' & I was impressed, it was a beautiful all Sapele job), but I looked at that joint & enquired how it got it's strength. Now you post & show me!
Like Markus I can see the merit in your system over the original, funny how the original twisted though, as you say the wood must have been a little hinky for it to want to twist because from what I've seen, that's quite a 'boxy' area up in there.
Users browsing this forum: No registered users and 179 guests
