Grain filler
Grain filler
Post by rocket » Fri May 27, 2011 4:36 pm
Hey all!! i'm considering using Timbermate as a grain filler on an archtop with blackwood b/s sitka top. In the past i've used West's epoxy which is good but with an archtop it is difficult to blade off, which means lots of sanding to get back to bare timber. Timbermate is much easier to sand but waterbased, and when using it to grainfill the pecentage of water to filler is much higher, should i seal with shellac first? Also i've never used grainfill on spruce before, do many of you deem it nessecary to grainfill spruce?
Thanks for any enlightenment!!!!
Re: Grain filler
Post by DarwinStrings » Fri May 27, 2011 5:57 pm
Spruce is a softwood, no grain to fill. I use Timbermate straight onto the bare wood, you can dampen the wood first, dry it and give it a light fine sharp sand before filling.
Re: Grain filler
Post by Allen » Fri May 27, 2011 6:25 pm
As Jim said, stay away from the Spruce.
Re: Grain filler
Post by rocket » Fri May 27, 2011 6:45 pm
Thanks Jim/ Allen
Cheers,,,
Re: Grain filler
Post by kiwigeo » Fri May 27, 2011 8:18 pm
"If it's spruce...then grain filler has no use"
liam_fnq
Re: Grain filler
Post by liam_fnq » Fri May 27, 2011 8:29 pm
I used CA to grain fill cedar once.
Note I said 'once'.
