Cello luthier needed around Byron
matthew
Post by matthew » Fri Jul 15, 2011 3:44 pm
A friend of mine in Byron bay needs to have his daughter's cello repaired. Neck is part busted out of mortise, and the whole thing needs a proper neck reset, setup and new bridge cut. A job for someone who's done it before.
Can anyone recommend a luthier in the area?
I'm not doing the job because too far away. He may have to go into Brisbane I guess.
matthew
Re: Cello luthier needed around Byron
Post by matthew » Fri Jul 15, 2011 3:55 pm
matthew wrote:A friend of mine in Byron bay needs to have his daughter's cello repaired. Neck is part busted out of mortise, and the whole thing needs a proper neck reset, setup and new bridge cut. A job for someone who's done it before.
I'm not doing the job because too far away. He may have to go into Brisbane to see Olaf I guess.
Post by simso » Fri Jul 15, 2011 7:43 pm
Its not hard, I can walk you through the repair if you want
matthew
Post by matthew » Fri Jul 15, 2011 8:53 pm
Yes it is not a difficult repair.
However, as I said, I am too far away - 10 hours drive. That's why I am trying to find someone in the Byron Bay area for my friend.
Users browsing this forum: No registered users and 192 guests
