My French polish instructional DVD is now available. The two DVD set has over 5 hours of video instruction covering sanding, pore filling, egg white sizing, mixing and applying shellac, polishing problems areas like around bridges and fretboards and rubbing the finish out to a high gloss or satin.
You can see previews and order hard copies here:
http://apprenticepublishing.com/frenchpolish.htm
If you prefer to access it online then it is available as part of my online classical guitar building course via my website.
http://www.obrienguitars.com/?page_id=84
O'Brien French Polish DVD
- ANZLF Approved Supplier
Re: O'Brien French Polish DVD
Here is the comlete first link for hard copies of the French polish DVD
Well, for some reason I can't get that to work so just copy and past the link to your browser.
Here you go:Robbie O'Brien wrote:Well, for some reason I can't get that to work [...]
(You had a an invisible character between the o and the m of "com". Copy-Paste the previous link into a simple text editor and you'll see that "invisible character".)
Thanks for the heads up Robbie.
i'm sure it's up to the impeccable standard of your previous works.
Users browsing this forum: Google and 88 guests
