Parlour Guitar
Parlour Guitar
Post by ozziebluesman » Sat Sep 24, 2011 8:04 am
Hi to you all,
This is a Parlour sized guitar I have been working on for a few years and finally finished it this week. This one is for a mate who wanted a small, fingerstyle guitar. I used the Scott Antes plan as a guide but used parbolic bracing and a standard x brace design. It is a bright sounding guitar with good projection. The guitar has a wide, almost flat fingerboard profile as per the plan which would take a lot of getting used to if it was a regular player for myself.
Top: Western Red Cedar for Shane at High Mountain Tonewood
Back and side: Blackwood from Bob Connor
Fingerboard, bridge, endgraft, binding and headplate : East Indian Rosewood for Shane HM Tonewoods
Rosette: Koa
Shellac, French Polished finish.
Here are a few pics:
Thanks for your attention
Clancy
Re: Parlour Guitar
Post by Clancy » Sat Sep 24, 2011 11:40 am
Sweet! :cl :cl
Lovely work on the headstock.
What's the neck?
You've just moved a Parlour model further up my list.
Re: Parlour Guitar
Post by charangohabsburg » Sun Sep 25, 2011 3:54 am
That's a very nice looking guitar! :cl
What is the width (depth) of the sides? The guitar looks a bit "fatter" than other parlour guitars I have seen, but maybe it's just an optical illusion due to the camera position.
Re: Parlour Guitar
Post by Allen » Sun Sep 25, 2011 6:17 am
I love little guitars. That one is a cracker Alan. Great combination of colour and timeless design.
Re: Parlour Guitar
Post by Kim » Sun Sep 25, 2011 7:40 pm
Lovely guitar Alan, I really like the satin finish, especially on the smaller bodies, nice package all over the style of the bridge and rose fit in really well.
Well Done :cl :cl :cl
Re: Parlour Guitar
Post by Bob Connor » Tue Sep 27, 2011 10:43 am
Lovely work Al. I like that headstock as well.
Re: Parlour Guitar
Post by ozziebluesman » Tue Sep 27, 2011 9:50 pm
Thank you Gentleman for your comments.
Marcus: The sides are 100mm at the butt and 85mm at the neck block. I used the Scott Antes Concert guitar plan as a guide but changed the bracing design and used a 24.9" scale.
Re: Parlour Guitar
Post by charangohabsburg » Tue Sep 27, 2011 10:13 pm
Thank you Alan. That's an interesting design. :D
Re: Parlour Guitar
Post by Taffy Evans » Fri Sep 30, 2011 8:49 pm
Great little guitar Al, nice and neat and nice blend of timbers, well done.
Pappy Green
Re: Parlour Guitar
Post by Pappy Green » Thu Nov 10, 2011 6:31 pm
Bello
Re: Parlour Guitar
Post by Taffy Evans » Sat Jan 07, 2012 10:32 am
Hi Al, I'm playing catch up again. Very nice looking guitar, I think I may have seen it a few times during its build process, it looks great finished. Well done.
P Bill
Re: Parlour Guitar
Post by P Bill » Fri Jan 13, 2012 8:08 am
Beautiful as usual Alan. It's hard keeping up with all your guitars!
Re: Parlour Guitar
Post by woodrat » Sat Jan 14, 2012 7:01 am
Hi Allen, Beautiful work....lovely tonewood combos....well done! :D
luke_lee
Re: Parlour Guitar
Post by luke_lee » Fri Aug 03, 2012 6:34 pm
Hi Alan,
I think this is a very cool guitar, I really like the shape and have been inspired to make a parlour style guitar. I am just CAD’ing up my plans, and was curious about your dimensions. You mentioned you worked off the Scott Antes plans but from my calculation is seems narrow compared to other parlour plans. Dose this sound correct?
Scale: 24.5“, but you used 24.9”
Body - 18.25” = 464mm
Upper bout - 9.13” = 232mm
Waist - 7.13” = 181mm
Low bout - 12.25” = 311mm
Thanks Luke
Re: Parlour Guitar
Post by ozziebluesman » Fri Aug 03, 2012 7:34 pm
G'day Luke,
The guitar I built used the same specs as you have supplied and I used a 24.9 inch scale length. My bracing was an experiment where I used 7.5 mm wide X brace with a parabolic shape with the higest point being 14mm at the x intersection down to 2mm. Similar specs for the tone and finger brace and I used a fairly heafty transverse brace as per the plan. I also used spruce soundhole patch.
The guitar has plenty of volume and the cedar to I used produced a good tone. The Scott Antes plan has been used by many builders and most change the brace dimensions as it is a bit on the heavy side. Some have used a 13 frett to the body as well with good results.
I have collected a few threads on the Scott Antes plan when I was researching the plan. I can send them to you if you think they might be usefull.
Re: Parlour Guitar
Post by Lillian » Wed Aug 08, 2012 9:33 pm
Alan, it turned out a treat. Has your mate seen it yet? I'm sure he's going to be thrilled.
