Makita Router on Ebay
auscab
Post by auscab » Wed Jan 04, 2012 1:51 pm
I just saw this on Ebay and thought it looked like a good deal.
if any one is looking for one :)
http://www.ebay.com.au/itm/200694897795 ... 1423.l2649
needsmorecowbel
Re: Makita Router on Ebay
Post by needsmorecowbel » Wed Jan 04, 2012 4:46 pm
That's a great deall. I have one of these. The only complaint I have about the unit is that the collet gets a little rusty with use and the 1/4 inch insert also gets rusty as a result. Having a good break Rob?
auscab
Post by auscab » Wed Jan 04, 2012 7:58 pm
Yes Stu having a good break thanks.
Rusty collet,thats a strange one,must be moisture in the work shop ?
I have had a few of these, broke one once with a big router bit, a 50mm rebate cutter,the biggest rebate cutter Carbitool had,[ My mistake, a crazy big bit]the vibrations cracked the Armature or the machined shaft the Armature is on where the collet screws on to, its a one spanner job with a button that stops the shaft spinning.I had to drop back to the 35 mm cutter.
The previous design was a two spanner job and stronger.Both great routers though.
Post by simso » Wed Jan 04, 2012 9:24 pm
Same as mine, Ive had that router for about 16 years now, its strapped to the underside of the router table.
Only issue I ever had was the aluminium base cracked and split. Had to weld it up and skim the bottom to make it flat again but thats the only thing thats ever gone wrong with it
Would gladly buy another.
Users browsing this forum: No registered users and 210 guests
