Hi Zendo, planing across (or at least diagonally to) the grain helps and lets you get down close to target thickness quite quickly. Be careful though to get the thickness reasonably even, I find it easy to get it too fast uneven!zendo wrote: [...] Indian Rosewood classical guitar back down to a reasonably good sounding thickness. [...] planing took out chunks..
I also have the Veritas scraper plane (the "big" one) and never bothered a lot with honing, I find it much less critical than a normal plane blade to produce a nice surface.zendo wrote: [...] I have just bought a Veritas Scrapper Plane but have baulked at the honing stage which I always find difficult [...]
Using only the scraper plane would not be the fastest way, but doable. If your scraper plane is not the one with the wooden handle it certainly will not be much fun and previously planing across the grain with a normal plane would be almost a must, in my opinion.zendo wrote: [...] it seems shaving from 3mm to 2mm is a very slow process.... [...]
A thickness planer or a thickness sander? I think thickness planers have been used for such tasks, sticking the back respectively side veneers to a backing panel, but I believe this can still be risky or even dangerous not only for the wood. If I were you I would not try to mess with thickness planers and thin wood. If it is a thickness sander I have not said anything.zendo wrote: [...] I could use a thicknesser at a workshop I can use but I don't dare go there....
Hi Robert,zendo wrote:I am an independent sort of bloke which is why I stubbornly make this guitar by myselfHowever I am stuck with how to effectively and more quickly shift the Indian Rosewood classical guitar back down to a reasonably good sounding thickness. No doubt when I get to the sides I will have the same problem. The wood is currently about 3mm and according to my notes should get to between 2.5 and 2mm no less. I have tried sanding (hopeless), scraping with scrappers in a veritas holder (much better), planing took out chunks.. I have just bought a Veritas Scrapper Plane but have baulked at the honing stage which I always find difficult (given the cost I will eventually make good use of it) ... it seems shaving from 3mm to 2mm is a very slow process.... I could use a thicknesser at a workshop I can use but I don't dare go there.... help... any ideas welcomed... hello Kiwigeo... how's the Lute going? I am playing mine and sometimes wish I had stayed playing classical guitar as well.
Hello Graham, Actually my new machine should have a shim on the other side because B (terminology from the manual) is about 1 or 2 shims width greater than A but the method of adjusting is to loosen up the unit and try it without shims, which would be impossible to get in on that side anyway. I still haven't mastered it but I am taking your advice about passes and having the knowledge that a glued up back is best thicker in the centre anyway. Great advice.Graham McDonald wrote:The trick to the Carbatec 16" sanders is not to try to do too much at one time. On a glued up guitar sized back (or soundboard) I would adjust the wheel no more than 30° per pass, and less if it is an oily piece of rosewood. I suspect they don't come from the factory with the feed belt and drum exactly parallel. I shimmed the outside of the feed belt support about 1mm originally and probably should do it again. I think even when they are well set up there will be some flex in the drum and some fraction of a mm difference in thickness from inside to outside. I never really expect them to sand a back or soundboard totally evenly. For each adjustment of the wheel I run the piece through twice, turning it around for the second pass so the sanding to each edge is even, but the centre will be a bit thicker, which I figure is usually not a bad thing anyway.
wouldn't do without it though!
g
Useful for sides but not so useful if you're thicknessing a glued up back.ScottC. wrote:A Safe T Planer makes quick clean work of EIR
https://store.schoolspecialty.com/OA_HT ... tem=349134
ProfChris wrote:I found a toothed blade for my plane made a huge difference. Probably the best solution for thicknessing with hand tools. I also have a Record scraper plane, which works well but is much slower.
Toothed blade down to nearly the thickness, scraper plane or card scraper to finish off. Mind you, I only do soprano ukes, so there's far less work involved - 20 mins or so to thickness a back.
