Hey Trevor, in the design book on page 4-63 you mention that a couple of top woods in the chart (4.5-3)has to much mass to be a master grade guitar, is there somewhere in the book that explains the amount of acceptable mass?
BTW I just did the procedure to find the top thickness on my first Engleman spruce top, it worked but my thickness number with a "60" "f" came out to 2.35 which is a bit thinner that most of your examples. Is it normal for a classical top to be thinner?
Thanks, Scott C.
Top Mass
Re: Top Mass
The top mass depends on the size and shape of the guitar as well as the top's material properties, so whether a top is too heavy or not for a particular design can only be compared to your experience with that design.ScottC. wrote:is there somewhere in the book that explains the amount of acceptable mass?
That's in the right ball park for a classical top because, yes, they are normally thinner. Run the numbers again with f=75 and see if you get in the right area for a SS top, which will provide you with a check.ScottC. wrote:BTW I just did the procedure to find the top thickness on my first Engleman spruce top, it worked but my thickness number with a "60" "f" came out to 2.35 which is a bit thinner that most of your examples. Is it normal for a classical top to be thinner?
Re: Top Mass
Thanks, I need to get busy building, to try all the different ideas and factors.
I used f=75 and it came right in close with the chart in the book 2.94
Thanks again, Scott
Thanks again, Scott
My excuse is "I'm new"
