Hi guys,
Getting close to gluing the bridge on. This build I put a coat of zinsser shellac on the top to help protect it a bit during assembly, binding etc. Question is; do I need to scrape the shellac off the soundboard under the bridge? Or can I glue straight onto it? Only reason I ask is that it seems common practice to shellac the binding/rosette channels to prevent leaching of some glues.
Thoughts?
Shane
Can I glue a bridge over shellac?
Re: Can I glue a bridge over shellac?
No, you need wood contact, scrape it off
What Jeff said.Shane Woonton wrote:Hi guys,
Thoughts?
Shane
I tend to finish (French Polish) my guitars first and then fix on the bridge last. I fix masking tape over much of the bridge area during finishing so I only have to remove a small amount of finish from the periphery of the bridge footprint prior to bridge glue-up.
Thanks guys, it's as I expected.
Martin, typically I do the same and mask off the bridge area prior to finishing. This time the concept was lost somewhere in the midst of all the excitement.
Shane
Shane
Users browsing this forum: No registered users and 95 guests
