Can anyone advice regarding soundhole or removable pickups. I've browsed here and found good advice on other styles, and ended up getting a K&K for one of my acoustics. But I have a need to only temporarily amplify another guitar. I'd like to have a pickup on hand for those times when I need a pickup fora guitar that I cannot modify, for whatever reason.
Bern
Soundhole or removable pickup?
Re: Soundhole or removable pickup?
I have a DiMarzio Super Natural Plus that is easily installed and removed--has foam-padded slots for the soundhole--from most guitars.
It sounds good thru my Acoustic amp, which has lots of knobs
, but would clearly benefit from an off-board pre-amp. I think they've come down alot in price. When I bought mine it was $200+ in OZ, tho I had a friend send it from the US for half that....
A friend who is a professional muso reckons the biggest factor is the preamp, which I agree with....
I have a Fishman Neo D sound hole pick up that have used many times it is there cheapest bottom line pick up sounds good and would recommend cost me $75 second hand from ebay. Definitely need a decent DI or pre amp if you are going into a PA.
Cheers Luke
Have a look at the Baggs M1a soundhole pickup, they sound great. ..The "A" designation indicates this model is active i.e. the soundhole pick up itself has a built in preamp with volume pot and CR32 battery.
youtu.be/
youtu.be/
