Meet Stella
Meet Stella
Post by ozziebluesman » Sun Sep 16, 2012 5:16 pm
Here is my latest project, a small acoustic about the size of the old 50s Stella guitars. I like the size of these instruments as they so damn comfortable to play. The top is sita left a little thicker at 3mm with very light, red spruce bracing. Well I should say light for me. The bracing is parabolic and 6mm x 12mm and the top taps nice and strong but I reckon I may have to play this one in for a while for her to really open up. Time will tell.
I must fess up at this stage and tell you this is neck number two. I have made some mistakes on a few of my builds but always managed to fix the issues. This one was my own stupid fault and due to rushing and not using a neck profile template like I have done in all my other builds. It was one of those gut wrenching moments striking steel with the wood rasp on the back of the neck. Anyway, I gathered together the bigger pieces of the neck, strung them together and hung them in sight in the woodwork shop so as I don't do it again. One thing I did learn was how to massacre a neck to save a very nice fingerboard. :D
So here are a few picture of Stella almost ready for the finish stage:
Re: Meet Stella
Post by Allen » Sun Sep 16, 2012 6:22 pm
Is this your first slot head Alan?
Looks like you got a bit more work on that neck. You nervous mate? :)
Re: Meet Stella
Post by ozziebluesman » Sun Sep 16, 2012 6:37 pm
G'day Allen,
I have built a few slotted headstock before but this is my first bound fingerboard. Everything went ok so far. I have neck profile templates now so no more trying to wing it and cause grief. This is the guitar I am going to do my first herringbone purfling on the top so I was not sure how deep to inlay them. I will bend the herringbone as advised by you and the others. I haven't used curly maple binding before either so that will be fun as well. It has turned into a nice little guitar. I am going to keep this one so I have something to show prospective buyers.
Thanks for your comments mate.
Re: Meet Stella
Post by Allen » Sun Sep 16, 2012 6:55 pm
Curly binding can be tricky, but on the much gentler curves of a guitar it shouldn't be too much trouble. Either in the bender or by hand works. Most times I do it by hand as I can get a sense of how fragile it is and can judge how quick or slow I need to go.
Re: Meet Stella
Post by ozziebluesman » Sun Sep 16, 2012 7:33 pm
I have a build on go for my son and its at the French Polish stage. The binding on that one I used your method with the hot hide glue and installed three binding at the same time. I asked my son to call around for the afternoon as I thought it may need more hands but it worked a treat. I will try this method again but I reckon I will pre bend carefully on the pipe.
Al
Re: Meet Stella
Post by 56nortondomy » Sun Sep 16, 2012 10:29 pm
I used curly maple bindings on the classical i just finished. I bent them with a silicon heat blanket, no problems at all.
Users browsing this forum: No registered users and 161 guests
