Heads Up....QLD Luthiers
Post by woodrat » Fri Nov 30, 2012 5:28 pm
Hi everyone....Perhaps someone is looking for a Twin Drum sander....this one is on eBay in QLD....starting off about 1/2 price of new but it looks like it has done a bit of work....
http://www.ebay.com.au/itm/Twin-Drum-sa ... 2a267a0513
...hopefully helpful to someone....:)
Re: Heads Up....QLD Luthiers
Post by woodrat » Fri Nov 30, 2012 5:37 pm
...heres another one in QLD...could be a bargain for someone who can fettle it (see description)...
http://www.ebay.com.au/itm/Wide-Belt-Sa ... 1e74d34b06
auscab
Post by auscab » Sat Dec 01, 2012 12:34 pm
Nice machines John.
I have one of the first ones you put the link to,the twin head one, it came with a 80 and 120 grit fitted.It worked ok with that on it but was easy to get burns when it wore out a little.
I just changed them over to 60 grit on both rolls and look at this machine as a means to thickness only from 4mm down. its great.
The timber goes to the bench to be scraped and fine sanded . scraping after sanding is a little bit of a no no in my book ,but it's what ever get you there when it comes to the cranky timbers.
Post by woodrat » Sun Dec 09, 2012 3:04 pm
Yes Rob,...nice machines...I wish I had one myself...will have to get by with the Preformax 16/32 for a while yet though...
One of those machines has been relisted at $200 lower than before...If you are the only one to bid you could get it for well less than 1/2 price....
http://www.ebay.com.au/itm/Twin-Drum-sa ... 2a26b50964
The other one was popular...it attracted 24 bids and went for $765...not bad for something that just needed a belt adjustment....:) Well done whoever got it....perhaps an ANZLFer...
Users browsing this forum: Google and 129 guests
