1890 Martin restoration
Robbie O'Brien
ANZLF Approved Supplier
Post by Robbie O'Brien » Sun Mar 24, 2013 10:23 am
I recently had an old Martin guitar come into the shop for some work. With John Hall's help we were able to determine that this is a model 2 from 1890. It was strung with steel strings which is way too much tension for this little guy. Maybe that is why the left part of the x brace was completely broken in half. Someone has tried to repair it but improperly. With John's help we determined that to do it right the back needed to be removed so that we could get inside the guitar. The bindings, tuner knobs, heel and end caps and rosette rings are ivory. The bridge pins appear to be plastic, , not original. The back and sides are Brazilian rosewood and the top spruce. On a scale of 1 to 10 the pucker factor was a good solid 12 as I removed the back. It took me at least 2 hours to remove it. Care was taken to keep the ivory bindings and the dark/light back purfling veneers intact. Now that the back is off I can get into the restoration of the braces.
DSC02360 (640x427).jpg (185.62 KiB) Viewed 11357 times
DSC02359 (640x427).jpg (219.75 KiB) Viewed 11357 times
DSC02357 (640x427).jpg (207.62 KiB) Viewed 11357 times
DSC02355 (640x427).jpg (215.86 KiB) Viewed 11357 times
DSC02353 (640x427).jpg (177.89 KiB) Viewed 11357 times
DSC02352 (640x427).jpg (224.58 KiB) Viewed 11357 times
DSC02351 (640x427).jpg (221.63 KiB) Viewed 11357 times
DSC02347 (640x427).jpg (204.48 KiB) Viewed 11357 times
DSC02327 (640x427).jpg (160.5 KiB) Viewed 11357 times
DSC02322 (640x427).jpg (206.42 KiB) Viewed 11357 times
DSC02305 (640x427).jpg (213.57 KiB) Viewed 11357 times
www.obrienguitars.com
Re: 1890 Martin restoration
Post by ozziebluesman » Sun Mar 24, 2013 6:38 pm
Thanks Robbie. I almost had a tear in my eye reading this post. It would have been very special to be able to bring back to life such a truly vintage instrument.
Post by Kamusur » Sun Mar 24, 2013 7:30 pm
Great work Robbie, but hell what about the Patina on the inside? ,, its a 12 out of 10 as well.
Steve.
Crafty Fox
Post by Crafty Fox » Tue Mar 26, 2013 9:51 pm
Beautiful, can I have it?
Ken
n~dl
Post by n~dl » Fri Apr 05, 2013 2:05 am
Thanks for sharing this! I have a record of American Civil War music played on a model 2 (one that's probably 35 years or so older) and I've always wondered what an x-ray if the thing would reveal. If anyone wants an idea of how this guitar might sound, track this guy down if you can find it:
-Nate L
Post by Allen » Fri Apr 05, 2013 6:41 am
What sort of strings did you go with now Robbie?
tippie53
Post by tippie53 » Fri Apr 05, 2013 10:22 pm
glad I could be an advisor Robbie and I often help each other. I have a guitar from 1857 that I had to do about the same thing. Robbie did a fine job of displaying the project and his craftsmanship is impeccable .
Member of the board ASIA
Post by ozziebluesman » Sat Apr 06, 2013 9:37 pm
bump...
G'day Robbie,
I like to know what strings are you using on the guitar?
tippie53
Post by tippie53 » Sun Apr 07, 2013 2:24 am
I can't answer for Robbie but I suggest silk and steel unless you can find real gut strings .
willcall
Post by willcall » Fri Apr 12, 2013 8:23 am
Here's a song about Martin
He was born in the woods
Torn from his home.
Well, he was naked,
And destined
To be out on his own.
And he waited in darkness,
Hoping someone might see,
From something so rough,
What a treasure he'd be.
Stronger than steel and wood.
Seen me through the bad and good.
And when I'm hanging by a string,
Every little thing
Is understood
Between Martin and me.
He's hollow in the middle
From the shape that he's in.
He's either filled up with music
Or locked in his shell again.
And it takes some fine tuning
To make him come around,
But he's a huge piece of me
And I'll never put him down.
Every little thing
Is understood
He is a good friend,
And he has his own voice.
And you get what you give,
Sometimes it's just noise.
But if you treat him well
He will last your life long.
And if you're honest and open
Well, he will write you a song.
(Write you a song, write you a song)
Every little thing
Is understood
Every little thing
Is understood
-Zac Brown-
Users browsing this forum: No registered users and 90 guests
