.070" (1.78mm) Bearing for Weiss binding
Kim Strode
Post by Kim Strode » Wed Aug 14, 2013 12:42 pm
I started routing my Weissenborn for binding today and I'm missing the most accurate bearing size. I've got one too big, and one too small - it's always the way!
Although I can make do, I'm asking if anyone can lend me a .070" (1.78mm) bearing (Stewmac Catalogue Number 1298-070 ). I only need it for a day or two and can post it back immediately. I'd order one for Stewmac, but orders are taking around 3-4 weeks at the moment.
Kim Strode
Daylesford, Australia
Kim Strode
Re: .070" (1.78mm) Bearing for Weiss binding
Post by Kim Strode » Wed Aug 14, 2013 1:24 pm
If I could edit the above post I would, but can't work out how!
To add to the above. I tested the router with bearing on a scrap of wood and everything looked great. But when I did a cut on the actual guitar, the groove was too deep. Went to plan 'B' and used a different bearing and now the groove is not deep enough. An option is to thin down the binding, but now I have two differing binding channels and thought a different bearing might present less of a issue.
Kim Strode
curly
Post by curly » Wed Aug 14, 2013 1:31 pm
Gday Kim , I don't know what sizes are there but I did buy a swag of bearings from stew mac when I set up the kit .
I could have a squiz tomorrow for ya . Benefit is there would be no need for postage .
Pete
Kim Strode
Post by Kim Strode » Wed Aug 14, 2013 1:50 pm
Thanks Pete. That would be great.
Kim Strode
colburge
Post by colburge » Wed Aug 14, 2013 2:01 pm
Kim Strode wrote:I started routing my Weissenborn for binding today and I'm missing the most accurate bearing size. I've got one too big, and one too small - it's always the way!
I was in the same situation as you, and I just wrapped the bearing in a layer of cellotape until I got the right size, might be useful if you are dodgie like me.
Col
Kim Strode
Post by Kim Strode » Wed Aug 14, 2013 2:38 pm
Very clever Col. :D
Kim Strode
Kim Strode
Post by Kim Strode » Sat Aug 17, 2013 9:49 am
Thanks for the idea Col. 3 Winds of Stewmac Tape did the trick. Thank you.
Kim Strode
Post by kiwigeo » Sat Aug 17, 2013 10:50 am
Kim Strode wrote:Thanks for the idea Col. 3 Winds of Stewmac Tape did the trick. Thank you.
A new addition to the Stewmac catalogue......Stemac bearing shim tape.
colburge
Post by colburge » Sat Aug 17, 2013 2:46 pm
No problem
Col
Post by Taffy Evans » Tue Aug 20, 2013 2:36 pm
I have used the tape on bearing trick but forgot to tell Stumac about it. :lol:
Woodsy23
Post by Woodsy23 » Wed Aug 21, 2013 1:09 pm
I've also used tape on the router bit bearing to change the diameter and it worked well. I read somewhere that aluminium (aluminum) tape was good for this purpose (maybe that is what Stewmac have) and I tracked some down on ebay from a US supplier - a few strips for a few $. The next weekend, Aldi was selling a large roll of aluminium adhesive tape for about $4.
I think the thickness is about 0.3mm.
Woodsy
PS. Aldi's also sells double sided tape from time to time and I found that it is also as good as the 3m stuff.
liam_fnq
Post by liam_fnq » Wed Aug 21, 2013 3:43 pm
Do you wrap it so that it overlaps itself of do you need to butt joint the wraps? Serious question.
Post by kiwigeo » Wed Aug 21, 2013 4:00 pm
liam_fnq wrote:Do you wrap it so that it overlaps itself of do you need to butt joint the wraps? Serious question.
I prefer to overlap the ends of the tape.....I just love it when the router goes bumpity bump and I also love the pretty scalloped binding channel it leaves behind :D
Post by Taffy Evans » Wed Aug 21, 2013 4:35 pm
Good thought re the Aluminium tape, I have a few rolls from making my own truss rods over the years. The copper adhesive backed screening foil my work also.
liam_fnq
Post by liam_fnq » Wed Aug 21, 2013 5:55 pm
Helpful as always.....................
Post by kiwigeo » Wed Aug 21, 2013 8:27 pm
Butt joint the wraps and offset joint for each layer if more than one layer. Any unevenness or gaps will affect how router registers off side of the instrument :)
Users browsing this forum: Google and 63 guests
