Durability of Mirotone Pre-Catalysed Lacquers
Jeremy D
Post by Jeremy D » Tue Sep 17, 2013 5:37 pm
Hi Guys,
I was just wondering if anyone has any info about the long term durability of this product? I used it on my first guitar with z-poxy as the pore filler. I have been playing it for a year about an hour a day. I have visible wear on the lower bout where my arm rests and also on the back of the neck between the first and 5th fret.
I am about to put the finish on my second using the same stuff but with boatcote as the pore filler. I wonder if it could have been anything to do with my application? The wear looks sort of like someone has hit it with fine sandpaper. Sort of cloudy. I don't have any problems with sweat etc (not on any other guitars anyway).
Cheers.
Jeremy D
Re: Durability of Mirotone Pre-Catalysed Lacquers
Post by DarwinStrings » Wed Sep 18, 2013 10:20 pm
G'day Jeremy, can you buff it out? I have not seen anything like that on a mirotone finish. Cloudiness sounds like water in the finish but I sweat all over stuff in the tropics and have not seen it, could it be anything to do with the pore filler. I have never used that filler so not sure about how it can behave.
Jeremy D
Post by Jeremy D » Thu Sep 19, 2013 6:58 am
Hi Jim,
It could very well be to do with the pore filler. It was really strange, when I did the final buff all the pores sank a little bit. Previous to this the surface was really flat. I wonder if I didn't wait long enough for the epoxy to really harden. Anyway using boatcote this time as the factory is not far from me and it seems to be a lot nicer.
BTW its not really cloudy in the finish. More like it has been hit with 800 git paper and only in wear spots. I am not worried about it just curious, it has seen a fair bit of play time :).
Cheers.
Jeremy D
Jeremy D
Post by Jeremy D » Thu Sep 26, 2013 5:20 pm
I have studied the guitar and done some research here and on the olf. I believe this is all caused by amine blush from the z-poxy. In the bin with the z-poxy. Boatcote claims their product does not produce amine blush so hopfully one less thing to worry about.
Thanks for looking.
Jeremy D
Post by Bob Connor » Thu Sep 26, 2013 5:52 pm
I reckon you are looking at amine blush as well.
I've also noticed that z-poxy shrinks back under the buffer.
In fact if you check after a few months it will also sink back further into the pores.
