Band Saw Tire
hooked
Band Saw Tire
Post by hooked » Thu Oct 31, 2013 3:52 pm
All,
As a follow up in my unsuccessful quest to find manual for my CMWB-350 bandsaw, I now find I need to replace the tires.
First question......does anyone know who is the manufacturer of these saws? (Made in Taiwan in 1990)
Second question.....where can I get replacement tires?.... bearing in mind I still don't know the manufacturer.
THANKS
Daryl
hooked
Re: Band Saw Tire
Post by hooked » Thu Oct 31, 2013 4:29 pm
All,
I have found the answer to Q1. The saw is an old Grizzly G1019 derivative.
THANKS
Daryl
liam_fnq
Re: Band Saw Tire
Post by liam_fnq » Thu Oct 31, 2013 5:56 pm
Get some polyurethane tyres from ebay.
hooked
Re: Band Saw Tire
Post by hooked » Fri Nov 01, 2013 7:22 am
Done
THANKS Liam
hooked
Re: Band Saw Tire
Post by hooked » Tue Nov 12, 2013 2:32 pm
Liam/All,
Thanks. The polyurethane tires worked a treat. Service from Band Saw Tire Warehouse was super quick. Blade runs true with very little vibration in the saw. I had to have a little lie down after putting the new tires on. Talk about one armed paper hanger stuff. :wink:
Daryl
gpj1136
Re: Band Saw Tire
Post by gpj1136 » Wed Nov 13, 2013 8:15 pm
If you use a couple of clamps to hold the tire to the wheel to keep it from popping off while you are stretching it on it will go easy, also soak them in hot tap water but, not boiling.
