website entry in signature
- ozziebluesman
Hi there,
I have been trying to setup my signature area on my post section entry to my website.
If someone can explain the procedure that would be great .
Re: website entry in signature
In your user control panel there is a section where you can edit your signature.
You need to wrap the website address with the URL tags just like any of the tags you would add to a post in the forum.
your web site address
- ozziebluesman
No luck Allen?
OK....from memory I think I had this same problem. Years ago now.
I believe it was something that Bob had to tick in some part of the forums preferences for me.
It seems to work without putting the URL's at each end .
I just put my one back on then off then on again.
Just the complete web address and when I checked my signature on a post it was blue.
- Dennis Leahy
Alan,
try adding the "http" part at the beginning
http://
www
hamleyfineguitars
com
If I write it out correctly, the forum software will "interpret it" correctly, and not show the http part, but try adding it all.
Maybe I can type it out, if I leave spaces: ht tp:// www . hamleyfineguitars . com
Do that, but with no spaces.
http://
www
hamleyfineguitars
com
Another damn Yank!
- ozziebluesman
Thanks Dennis and Rob tried both those methods but no luck.
I will send Bob a pm tonight.
Al
Al
Or you can simply forward $500 to Bob and he'll "flick the switch" on the forum software
