Soundhole shape???
Soundhole shape???
do you think that altering the soundhole shape , as long as the same area is maintained would effect low freq resonances?????????? i.e. oval, triangle etc?????
Re: Soundhole shape???
There's the famous quote from Jimmy D'Aquisto, who, when asked why his sound holes were oval replied along the lines of "Sound is like water out of a hose pipe. When you squeeze the end it goes further".
Who am I to argue?
Seriously, I don't think it makes too much difference except that it may alter the Q of the resonance a little. A circle has the lowest perimeter length for the area enclosed and the drag as the air moves through the sound hole will be a function of the perimeter length. Less length, less drag, higher Q. I have no experimental data or analysis that demonstrates that, though.
Who am I to argue?
Hmm interesting concept the hose analogy!!!
I have a new small cnc that opens up a lot of new possibilities in soundhole shape...here is a practice soundboard I was playing with and got me to thinking about the shape, seems to me that as long as the area is the same it should be ok, but I am no engineer and consult the "books" on most everything I have a question with, and altering the shape definitely opens up new aesthetic ideas!!!!
- PICT0015.JPG (176.6 KiB) Viewed 8664 times
- PICT0014.JPG (173.56 KiB) Viewed 8664 times
- PICT0013.JPG (174.65 KiB) Viewed 8664 times
- PICT0011.JPG (180.54 KiB) Viewed 8664 times
Yes, a CNC machine opens up the possibility for endless eccentricities!
- woodrat
Boom Boom Trevor...
