accelerometers as sensors for FFT ect.
wadkin
Post by wadkin » Sat Mar 01, 2014 10:55 am
Hi there I'm new my names Alf and I'm a BSc Musical Instruments student in London Metropolitan uni, England.
Just wondering is anyone has tried using accelerometers as pickups for spectrograms/Q testing. From what little I'v read they tend to have a limited bandwidth but that's okay for my purpose are they any good?
http://www.analog.com/library/analogdia ... hones.html article
http://www.guitarandampshop.co.uk/acata ... ystem.html
ready made unit based on piezo film accelerometer
I don't have a clue about electronics, what one should I buy? how would I mount/solder it ect. would a pre-amp be required?
I stupidly bought this one and it's tiny 3mm x 3mm would need to stick it to a circuit board with solder past and heat gun or something,
I think all this is a bit over my head.
http://www.ebay.co.uk/itm/171118848043? ... 1439.l2649
auscab
Re: accelerometers as sensors for FFT ect.
Post by auscab » Sat Mar 01, 2014 12:08 pm
Hi Alf ,
I cant answer electronic questions . I'm not mentally equipped in that way :D
But I will say Welcome here , and I like you user name too . I have some machines with that name which I'm very fond of.
So I'm bound to read all your posts.
Post by Trevor Gore » Sat Mar 01, 2014 1:39 pm
Try contacting Mark French:
http://web.ics.purdue.edu/~rmfrench/Contact.html
He's done a lot of that type of work. Tell him I sent you :lol: .
Depending on exactly what you're after, you can get a long way using a microphone and a spectrum analyser like Visual Analyser (google it). It's a free down load. Instruction for use are here (link at the bottom of that page).
wadkin
Post by wadkin » Sun Mar 02, 2014 10:13 am
Trevor Gore wrote:Try contacting Mark French:
Indeed he mentions them in his book he's certainly the man to ask
I'v got VA and A condenser mic which is probably more than enough to play with, although I'm having trouble with getting averages for frequency spectograms.
I was just thinking that an accelerometer might be more consistent and could save the hassle of mic placement.
