Hi what would be the most accurate window function for measuring q values?
I'v been using the Hann (Hanning) function but I don't know if another one would be better?
Also I'm not sure whether is should average out the whole sample or what, I'v been using SpectruPlus and setting peak to 'infinite hold'
got some fairly meaning full results but it totally changes if I alter the settings so doesn't install me confidence, but I'm guess this is to do with natural limits of ffts.
I'm using sample size of 262144 sample rate of 96000(I think audacity default sample rate)
Window Function for measuring Q values
Re: Window Function for measuring Q values
In my view the choice of window function is less important than setting the most suitable spectral line resolution. There's a discussion and guidance on setting spectral line resolution in Appendix A-I page AI-2 in the black book. There's a discussion on choice of window function here. As ever, the choice depends on what it is you're trying to do, but I think the limit of accuracy for measuring Q is going to be set more by the spectral line resolution than the window function at the lower end of the frequency range. At the high end of the frequency range you're better off trying to measure sound spectrum absorption in a way that is independent of the shape of the material sample, but don't ask me how to do it! Visual Analyser lets you choose no smoothing window, so one less thing to mess with your data.
- wadkin
- Wandoo
Okay so I changed the sample rate to 22050 so with a sample size of 262144 that would give a resolution of 0.0841Hz surely that should be pretty good no?
now I'm getting values for Q over 400 hundred 0_o hmmm
I guess I should just choose a setting and stick with it so at least I get a relative comparison between boards.
Users browsing this forum: No registered users and 31 guests
