Piano timber
Piano timber
Just wondering if there is any generic timber used in pianos.........suppose that depends on what country it was made.
I have recently came across a wrecked piano in a junk yard that had some nice 100mm x 100mm timbers in it. The grain was very straight and slightly pinkish. I thought it looked like Oregon in colour but could it be cedar?
Hope someone can shed some light on it as the piano is sitting in the open but the entire frame is still in good condition and could be put to good use.
Re: Piano timber
Pianos that I've come across generally have spruce soundboards and supports. English and European pianos will probably be some type of European spruce of not particularly high quality so it won't be that stiff.
I use the 100 x 100 for back bracing in my instruments
Re: Piano timber
Thanks Bob,
As I have a box of brace wood already, I'll keep it in mind for a while.
Re: Piano timber
Craig Lawrence
Re: Piano timber
Yup.
I do cut it up Craig. lol
Most of it has gone into Weissenborn backs which are damped by sitting on your knee anyway.
I do have an idea of making a double backed Weissy to get around this problem however.
Re: Piano timber
If anyone is after this particular wrecked piano, but very worthy of salvage for wood, it is in a junk shop in Seymour, main road in on the left.
Re: Piano timber
Do it!Bob Connor wrote:Yup.I do cut it up Craig. lol
Re: Piano timber
Rather than a double back those Weissys needed what Mountain Dulcimer players call a "Possum Board". This is actually an additional back on which the instrument sits only sits separated by some distance holders, sometimes not even attached permanently.Bob Connor wrote: Most of it has gone into Weissenborn backs which are damped by sitting on your knee anyway.
Normally those possum boards are too close to the back to work really well. The minimum distance to the back should be about 25mm if the board is generously perforated, or up to more than 40 mm if it is just a solid board. A few slots in the sides between the two backs is not enough to make a huge difference (but still better than nothing).
This is what I came up with instead of ditching this almost never played, bad sounding cheap mountain dulcimer. Oh well, I still don't play it, but at least it looks a bit prettier (which wasn't too difficult to achieve!
Just to stay on-topic: of course instead of firewood, piano wood would also do the trick:
Users browsing this forum: No registered users and 26 guests
