Also if anyone knows where to get this stuff that would be most helpful
I have never worked with phenolic resin based material, but if it is true that this kind of material only can be glued with epoxy it is no surprise that removal presents some problems.simso wrote: its easy to feel and work a glue line on a glued piece of wood, on a richlite board you cannot feel a glue line between it and the piece of wood your parting it from, so its very easy to slice through the richlite rather than the glued joint [...]
