Heres a question for you
Okay, youve been dicking around with the dovetail on your 12 string so much you havent noticed that youve shortened the neck so much that the 14th fret now lies about 4.5mm bridge side of the neck/body joint.
As far as I see it the options are thus:
1. make a new neck.
2. make a new fretboard using a slightly shorter scale length. Measuring along the neck with nut in position the new body/neck join is at 358mm from he nut. Using my Excel fret position calculator that makes the new scale length 646mm.
3. Live with the 14th fret not being at the body/neck joint (I think I will end up having nightly dreams about this for the rest of my life).
So which option? Im already favouring optiion 2. Less work than making a new neck.
Cheers Martin
1. make a new neck.
Cheers Martin
- graham mcdonald
Nothing at all wrong with a 13.75 fret neck. I have a 14.37 fret neck on my favourite sounding guitar. The body is also way deeper than the plans. But is sounds great. If a 12, 13 or 14 fretter is OK, why not a 13.75 fretter?
I can't see how 4.5mm would make much difference as long as the bridge sits on the x/bridge plate in about the right place.
I've said this before, but i don't believe there are any 'should's' in guitar building, only 'could's'.
Now you just gotta learn to dream about how you have a unique 13.75 fret neck guitar and how nice it sounds.
- matthew
My first response was along those lines too, actually.
I don't think a 13.75 fret neck would pose a problem for a player even if they did notice. You'd adjust in the same way you adjust to any other playing challenge, like putting a capo on fret#1 and adjusting to play fret 14 at fret 15!
If the guitar sounds good, that 4.5mm won't make a difference to the price.
Hmmmm ... and then I thought, Nah, there's probably an unwritten holy secret "should" that says the fret MUST line up with the rib. I won't show my ignorance by suggesting that it matters not a bee's fart ...
Okay moving the nut back isnt an option. the headstock is already veneered and bound. I've pretty much decided to go for a shorter scale length which wont be noticed by anybody but me and anyone with a ruler. Ive already checked out bridge patch position and new bridge location wont be an issue.
Thanks for all the feedback.
646 mm is pretty close to 25,4", so nothing unusual about that.
One option that you didn't mention (and I don't particularly like this method, but I have seen it done some times) is shimming the heel with a contrasting wood, thereby gaining the necessary length to maintain your original scale length.
I actually try to have the 14th (or 12th) fret sit a smidge out form the body joint on the neck side, just so there is a little 'meat' there, as an insurance so the neck fitting process doesn't result in the fret sitting over the body. I have had that happen, and I sure don't like that look...
I would go for option 2.
Arnt Rian,
Norway
Norway
G'day Martin,
I agree with Jack ,in that a shorter scale is a a good thing on a 12 string. With a wider neck ( mine is 1 15/16" @ nut ), and 6 extra strings to deal with , I find a shorter scale quite welcome. less pressure is required to fret a string ,and a shorter reach between frets .I believe you need all the help you can muster for 12 string playability.
Because the neck is shorter , the strings have slightly less leverage too.
As Arnt and Jack also pointed out , 25.4 " (645 mm. ) isn't considered short. My 12 is a 24.9 " scale ( 632.5 mm. ) ,,and a 13 fretter !
Cheers , Craig
Cheers , Craig
Started French Polishing the body today...two body coats on so far. Pore filling was done using z-poxy finishing resin. Two neat coats of same followed by final coat thinned down 50% with alcohol and then lightly sanded back with 600 grit W and D paper. In the background of first pic can be seen the offending neck...now a special "short scale" neck.
