If you, like me are often tempted to (and actually do) reach around the still moving blade of your not so new bandsaw, then you might consider to give this tool a brake (for its birthday, Christmas, or whatever).
The blade of newer bandsaws stops spinning quickly once the machine is turned off, according to European Standards ten seconds or less are considered as a "reasonable short time" for a woodworking machine to stop after it has been switched off
*. My INCA bandsaw needed about 13 seconds, and also 10 seconds would still annoy me.
So I retrofitted the bandsaw with a foot-operated bicycle disk brake. When I step on the pedal a microswitch first cuts off power, which triggers the main switch off too. The foot one millimeter or so further down actual braking starts and the saw stops as fast as I want. Once I take foot pressure off the pedal the microswitch closes again, but as the saw's main switch is off
I have found this information on a HSE sheet here (see PDF "Retrofitting woodworking machine brakes WIS38")
Here some pictures of the "brake I gave" (to) my trusty bandsaw:
- The pulley with the disk is spinning counter clockwise, so that the plywood support of the brake gets pushed against the bottom of the saw frame.
- 2014_P7700_2242c.jpg (135.36 KiB) Viewed 57931 times
- The foot pedal, obviously!
- 2014_P7700_2243c.jpg (88.3 KiB) Viewed 57931 times
- The whole "brake system" in one picture.
The white thing hanging down from the fence is an additional switch, which allows me to "unplug" the saw without actually pulling the plug. ;-) - 2014_P7700_2248-2c.jpg (118.48 KiB) Viewed 57931 times
- The innards 2: microswitch, electric and mechanical wiring.
- 2014_P7700_2244c.jpg (97.56 KiB) Viewed 57931 times
- The innards 1: in order to keep the microswitch closed without using the brake's business end spring I had to install a spring (a section of a de-toothed old saw blade) to the pedal.
- 2014_P7700_2245c.jpg (82.89 KiB) Viewed 57931 times
Thanks for watching, and don't reach around a spinning blade!
