Lightweight headstock
slowlearner
Post by slowlearner » Tue Nov 11, 2014 12:15 pm
I'm always looking for crazy new ways of reducing weight. What I'm thinking about doing is using a core of kauri pine as a headstock. This is going on a 32" scale 5 string bass. So string tension is a little lower than your regular bass.
The timber is 50yo, well dried and extremely stable. It'll be scarf jointed on the neck with a died maple veneer on the back and a face veneer of liquidambar (as hard as rock maple). I'll then add another veneer to the back of the headstock/joint once the scarf joint is finished. What I'm concerned about is whether I'm substantially weakening the neck by doing this?
Thoughts? Concerns?
Pete
Re: Lightweight headstock
Post by kiwigeo » Tue Nov 11, 2014 1:37 pm
Why do you want to reduce headstock weight? Keep in the mind the effect it will have on sustain.
slowlearner
Post by slowlearner » Tue Nov 11, 2014 1:56 pm
hmmm, good point :)
Pete
Post by DarwinStrings » Tue Nov 11, 2014 7:20 pm
Google Ken Parker. There are a few bits and pieces of info and interviews out there on his light weight construction for electrics and you may be able to take something from that, he does do a bit of CF though to bring the stiffness up as well, something about raising the neck and body modes to higher frequencies.
Post by simso » Tue Nov 11, 2014 7:46 pm
I have some issues with lightening the headstock too much.
If the material is light, this is indicative of using a soft wood, when using a soft wood, there is allowance for things to move (oscillate / vibrate) under tension, when things move under tension they introduce new harmonics, whether this be good or bad is the unknown.
Post by kiwigeo » Tue Nov 11, 2014 7:48 pm
Do a bit of research on Steinberger guitars......note that while they are headless instruments there's alot of carbon fibre and other modern materials also used in these guitars.
Post by kiwigeo » Tue Nov 11, 2014 7:51 pm
simso wrote:I have some issues with lightening the headstock too much.
I tend to think of the neck and headstock as a dirty big energy sink. If the neck and headstock are free to vibrate then they're going to soak up string energy....something which on a guitar is generally in short supply.
Post by Bob Connor » Tue Nov 11, 2014 8:35 pm
I agree totally Martin.
A lead neck and headstock would be perfect if it wasn't so heavy.
regards
Post by simso » Tue Nov 11, 2014 8:47 pm
kiwigeo wrote:I tend to think of the neck and headstock as a dirty big energy sink. If the neck and headstock are free to vibrate then they're going to soak up string energy....something which on a guitar is generally in short supply.
Absolutley correct, and I do not disagree, I do not understand why gibson uses mahogany for necks rather than maple for that exact reason
Post by Bob Connor » Tue Nov 11, 2014 9:09 pm
Another reason why ebony is such a good fingerboard.
Lutherie Gervais
Post by Lutherie Gervais » Wed Nov 12, 2014 4:21 am
kiwigeo wrote:Why do you want to reduce headstock weight? Keep in the mind the effect it will have on sustain.
Yep ! I am actually adding weigth to my headstock !
I have studies to prove it ;)
You want the energy to go back into your guitar neck and body, not to let it go in a lightweight headstock.
slowlearner
Post by slowlearner » Thu Nov 13, 2014 8:14 am
I'm sure that's true on acoustic instruments... but electric bass is a whole nother kettle of ferrets.
If ever there was an instrument that had enough sustain or in the immortal words of my mother... "cut it out, that's enough!". Ie. too much sustain. Added to that, we can go put enormous, fat, rod-core strings on em and we could go on holidays and come back and it'd still be ringing. Bass players spend their lives trying to damp the strings.
A bigger issue for us bass players is shoulder pain, balance and neck dive. Adding weight to the headstock exacerbates all these problems. Hence my desire to lessen the weight of the headstock.
Pete
Post by Allen » Thu Nov 13, 2014 6:36 pm
One of the heaviest things in a bass head stock is the tuners themselves. Switch to the Hipshot Ultralite tuners. Two versions at the bottom of the page. They are the ones I use on my U-Bass.
needsmorecowbel
Post by needsmorecowbel » Thu Nov 13, 2014 8:33 pm
simso wrote:I do not understand why gibson uses mahogany for necks rather than maple for that exact reason
One of my favourite basses of all time is the Gibson Ripper... Had never really thought about the Maple construction of the ones up until 1977 until now; thanks Steve.
Allen's on the ball with hipshot ultralites. Nothing worse than super heavy tuners to tip the balance of the bass....
Stu
garryalb
Post by garryalb » Fri Nov 14, 2014 7:34 am
Gotoh also make a range of light bass tuners in traditional styles. Perhaps consider ditching the headstock altogether, my own bass is a 30" headless, perfect balance even when seated, a great lounge bass. I am a metal worker so the hardware wasn't a problem but parts are available. Lighter woods in bass necks are certainly different, I made several necks for the same instrument (acoustic bass) from different woods. Rock maple, Brazilian mahogany, New Guinea rosewood and kwila. The kwila won for me, the solid sound of maple with complexity in tone of mahogany, it is dense, stiff and very stable but may prove too heavy dependent on design. Just something else to think about, good luck.
Garry.
slowlearner
Post by slowlearner » Fri Nov 14, 2014 8:43 am
Allen wrote:One of the heaviest things in a bass head stock is the tuners themselves. Switch to the Hipshot Ultralite tuners. Two versions at the bottom of the page. They are the ones I use on my U-Bass.
Actually I'm using rotomatic style guitar tuners. They're more than strong enough for a medium/short scale bass. I find them to be slightly lighter than an ultralight and about 5% of the price. :wink:
But yeah, lighter tuners was right where I started. I'm trying to move beyond that now into even lighter stuff. As for neck timber, I use vic ash... although I might do something crazy with the next build that isn't vic ash.
Pete
