Side Marker Dot Jig - A No Brainer
Post by Allen » Sat May 31, 2008 5:37 pm
This jig might be old hat to a lot of you, but it's been a well kept secret from me. So after knocking one up today and giving it a run, I'm sold on how easy it is to get accurate and consistent results.
This is just some aluminum angle stock that I've drilled 2 sets of holes. One for the single dots, and 2 for the 12th fret marker. I scribed a line so I can align the dot to the appropriate place on the fret board.
The fret board clamped to the jig
I just use a cordless drill with a bit of tape on the drill bit for a depth gauge while holding the jig like this.
Finished results.
I really like this over the other methods that I've tried, as getting the dot off even by a fraction of a millimeter looks totally crap. The whole process only took about 4 minutes including glueing in the dots. Much longer to write this tutorial.
Hope that it's useful to you.
Post by Kim » Sat May 31, 2008 6:20 pm
Very schweet Allen, very simple yet effective.
Post by Bob Connor » Mon Jun 02, 2008 1:15 pm
Very neat Allen. I like it a lot.
Bob
Side dot marker
Post by Taffy Evans » Mon Jun 02, 2008 3:36 pm
Hi Allen I think thats a good one too, I'm drilling side dot holes tonight. I'm thinking that in time the aluminium hole might enlarge and not be so accurate. What I might do is to make a special centrepunch put it through the hole give a soft tap with a small hammer and drill out side of the jig. Just a thought. An adjustable jig for different scale lengths would be good.
Post by Allen » Mon Jun 02, 2008 4:58 pm
The alloy was cheap "free" and there's heaps of room to drill new holes, so I don't mind drilling some new ones now and then when it's required. I could have got a piece of steel that would potentially last a lot longer, but in Cairns, that's just one more thing thats going to rust. :shock:
Still a lot less trouble than the way I was going about it before
Post by sebastiaan56 » Wed Jun 04, 2008 6:47 am
Thanks Allen,
I have just as many problems as you allude to, the jig was a secret from me as well.
Sebastiaan
