Macassar Ebony
chappy
Macassar Ebony
Post by chappy » Mon Dec 01, 2014 8:44 pm
Anyone had troubles getting a finish on Macassar Ebony?
I am at the stage of applying finish to a ukulele that has Macassar Ebony back and sides. The sides are pretty good but the back, after several coats of shellac, appear to have "flat" areas, like a satin finish while the rest of that area is very glossy. When sanding the back the "satiny" spot smeared and enlarged.
Sorry no photos as I got the shits with it and wiped all the shellac off in an attempt to start again.
Someone, unfortunately, may have experienced this and can provide the answer to getting a nice stable finish?
Re: Macassar Ebony
Post by kiwigeo » Mon Dec 01, 2014 10:04 pm
Alan, how are you applying the shellac?
chappy
Re: Macassar Ebony
Post by chappy » Tue Dec 02, 2014 5:33 am
Hi Martin,
Initially applying shellac with a super fine nylon artists brush then sanding back.
After 4 or 5 coats I do a few thin coats with a cloth pad
Re: Macassar Ebony
Post by kiwigeo » Tue Dec 02, 2014 8:07 am
Not quite sure what your problem might be Alan. Whenever I get problems with a shellac finish one thing I check for is contamination on the wood surface. Once you've gone back to bare wood try wiping the wood surface with shellite to make sure the surface is clean. What sort of material is the instrument sitting on while it's being finished (eg non slip mat etc). Try padding on the first few coats of shellac and see if that makes any difference.
Sorry I cant think of any other reasons for you problems.
chappy
Re: Macassar Ebony
Post by chappy » Tue Dec 02, 2014 5:23 pm
Thanks for the input Martin,
I will tackle it tomorrow and see what goes. Other forums suggest it could be oil so I'll try the shellite approach.
Re: Macassar Ebony
Post by kiwigeo » Tue Dec 02, 2014 10:23 pm
chappy wrote:Thanks for the input Martin,
You don't have any of those rubber non-slip mats in your workshop do you? I ask because I had a classical sitting on one of these mats and it picked up some silicon mold release agent off the mat and I ended up having to replace the back due to silicone contamination.
chappy
Re: Macassar Ebony
Post by chappy » Wed Dec 03, 2014 5:51 am
Hi Martin,
I do own one of those meshy non slip mats and use it frequently but this is the first time I've had finishing problem, first time using Macassar Ebony too. Maybe time to look for an alternative.
I will tackle it today and post a reply when I have a result.
This uke might end up as my non seller/player
Cheers and thanks for your help.
auscab
Re: Macassar Ebony
Post by auscab » Wed Dec 03, 2014 3:00 pm
Sounds like it's either the way you are applying the shellac and the timing between coats possibly, or the old silicon problem . If you suspect it may be silicon from the Mat you could try lightly wet sanding sanding the timber with some white vinegar.
It's used for the removal of cured silicon , so I just read .
A few days ago I used silicon to glue in a glass table top and was getting quite Pi$$ed off with trying to get the very last of the silicon smear off the glass. white vinegar worked for that as well . I shall never be without a bottle again . I never am any way cause I always need iron oxide water stain.
chappy
Re: Macassar Ebony
Post by chappy » Wed Dec 03, 2014 10:08 pm
Looks like I have cracked it today, I sanded back with 180 grit, then used a scraper over that and that got rid of the smears/smudges of whatever is was. I then used 0000 steel wool blown off with air, a couple of wipes with shellite and then a heavier or "flood" coat of shellac.
I have put on 3 coats of shellac now and all appears to be what will be a nice finish.
Thanks for the input, maybe I will post a finished photograph.
I got rid of the non slip mat and used an old towel.
Re: Macassar Ebony
Post by kiwigeo » Wed Dec 03, 2014 10:13 pm
That's great news Alan and yes please post some photos.
chappy
Re: Macassar Ebony
Post by chappy » Fri Dec 12, 2014 12:55 pm
Thanks all for the input.
I sanded back with 180 grit and then scraped, especially the smudgy spots, after which I flood coated with shellac 3 coats, a couple hand rubbed and finished with micro mesh pads to 12000. Finally a coat of orange oil.
Photographs attached on the final finish.
gpj1136
Re: Macassar Ebony
Post by gpj1136 » Sat Dec 13, 2014 6:25 am
When you finish with micro mesh, do you use water? I have been wanting to switch to shellac from lacquer but have trouble with the final leveling and polishing. I tried applying my coats with a sprayer the same as lacquer, and have nothing but frustration trying to level and polish.
Re: Macassar Ebony
Post by kiwigeo » Sat Dec 13, 2014 11:56 am
gpj1136 wrote:When you finish with micro mesh, do you use water? I have been wanting to switch to shellac from lacquer but have trouble with the final leveling and polishing. I tried applying my coats with a sprayer the same as lacquer, and have nothing but frustration trying to level and polish.
If I'm too lazy to level by spiriting off I level with 2000 grit wet and dry lubricated with the same walnut oil I use on the pad during bodying sessions. I go easy if I haven't done many bodying sessions as there's a risk of sanding through the shellac and leaving oil on bare wood.
Re: Macassar Ebony
Post by kiwigeo » Sat Dec 13, 2014 11:57 am
chappy wrote:Thanks all for the input.
Well that turned out alright didn't it? Looks great.
chappy
Re: Macassar Ebony
Post by chappy » Sat Dec 13, 2014 5:35 pm
To gpj1136,
I don't use any water at all with the micromesh, I think the water and shellac would not go too well together.
How many french polished tables have you seen with glass rings on them, or beer can marks, must the company I keep.
gpj1136
Re: Macassar Ebony
Post by gpj1136 » Sat Dec 13, 2014 6:58 pm
That is what I thought so I was sanding dry and it would gum up to fast. I'll try walnut oil next time. I would really like to get away from lacquer. I have a nice spray booth that filters with charchoal, but it's still nasty. Thanks
Users browsing this forum: No registered users and 90 guests
