neck blank question
neck blank question
Hello luthiers,
My father in law has offered me a bit of his timber stash: a 2m long piece of 150-year-old red cedar from an old church that was torn down in Box Hill, Vic, in the 70s. It's beautiful - perfectly quartered and a rich red chocolatey colour. Light as anything but very strong, carves and planes like mahogany.
The timber has a routed profile, but squaring it will bring down the cross section to 90x25.
I see neck blanks going between 610-650mm. Is that about right? How much would one typically use for a stacked heel?
Or if there's a better use than necks let me know!
Now I just need to convince him to surrender the other bits he has earmarked for a coffee table...
Cheers!
Rob
Cheers!
Rob
- 56nortondomy
Re: neck blank question
Hi Rob at 25mm thick i'd use 3 pieces for a stacked heel, i normally have one at 100mm one at 80mm and one at 60mm, so about 240mm in length.
Assuming you are talking about western red cedar and you are making a steel string guitar neck? Even though you say it is very strong and works like mahogany, you might like to think about reinforcing it with a carbon fibre rod. Belt and braces.
Miguel
Miguel
G'day Rob ,
It'd be Aus Red Cedar , Toona citiala which is closely related to the true mahoganies . It's a very light weight and somewhat fragile timber , perfectly suited for nylon string guitars but marginal for steel string unless additional stiffness is added .
It's a gorgeous timber to work , and particularly lovely to look at . I just hope its had time to air out from the farts of pious people !
Pete
Pete
Thanks guys,
So 610 + 240 + kerfs and f*ckups should get me 2 necks out of the 2m length.
I'm intending it for a classical neck, or a gut-strung parlour. Hopefully the pious farts will have transubstantiated by now Pete
For reinforcing, is the jury still out on carbon fibre rods?
Rob
Rob
Works fine for nylon string necks in my experience
That old stuff is beautiful so much more colour than the new regrowth.
I have a student using some recovered from old door jambs at the moment.
- 56nortondomy
I use CF in all my necks Rob, gives them that little bit of extra stiffness.
Thats very funny Petecurly wrote:G'day Rob ,
Pete
Steve.
