In a recent thread, Jeff (jeffhigh) mentioned:
"I could do like Brian Burns and tape the back on, glue on the bridge, test and modify."
Does that actually work? Is the connection to the sides solid enough with tape to get a reliable test of the closed box?
I glue my tops to the sides first so I can play with top mobility before closing, but would like to tune the back stiffness more accurately and with the small sound holes on most Selmer guitars I can't reach in to shave a brace. I've taken more than one glued back off to adjust. If tape would resemble glue for testing, that would be a huge game changer for me.
It sounds easy enough and I'll test it for sure next build. Trevor mentioned the time it took. How so?
Tape on the back for testing
Re: Tape on the back for testing
Brian makes it work. It relies on having a back cut exactly to size and taped such that there is no air leakage. Brian is pretty amenable, so perhaps give him a call to get all the details.Craig Bumgarner wrote:Does that actually work?
Compared to removing a glued on back for adjustments, I don't think the time issue will be significant for you!
You must be better at it than I. My backs are laminated and the hot knife tends to wonder into the first laminate (mahogany) and splits the laminate in places. Makes more a mess of it than I would like. In my removals, the back has already been trimmed to the sides and the glue fairly will set. My guess is it would be easier if I left an overhanging edge to guide the hot knife and, of course, do it will the glue has just started to set. I use Titebond for backs and understand the 15-20 minute idea.Trevor Gore wrote:Compared to removing a glued on back for adjustments, I don't think the time issue will be significant for you!
I still might have a go at the tape idea, just to see how it works. I'll try to contact Brian as well. Thanks.
I think we got our lines crossed there, Craig!
What that was supposed to mean was that using tape will make removing a back a lot faster than if you used glue, so the time that using tape takes will not be a significant issue for you.
Thanks for the uncrossing the wires! I'll let you know how it goes.
If you plan to get backs off then a photographers sealing iron is a useful tool. I used mine alot during my lute build both during top and back glue up as well as removal.
http://www.amazon.com/Hangar-9-Sealing- ... B0006N6Y0Q
