Classical scale length
Post by DarwinStrings » Thu Jan 22, 2015 1:57 pm
It looks like there is a choice here, 26" or 25.6" (Torres) for nylon strings, which do you chose?
Re: Classical scale length
Post by Trevor Gore » Thu Jan 22, 2015 2:48 pm
650mm is by far and away the "standard".
660mm is reasonably popular on flamenco guitars.
630mm and 640mm have been used by those with smaller hands.
I've built classicals with both 650 and 660mm scales. Only about 50% of people notice the difference, usually those who have only ever played on 650mm scales, and they seldom figure out why they keep missing notes (because there is only one scale length, right?).
The extra tension you get running at 660mm can be useful if you have a guitar that likes high tension strings.
There might be more scope amongst nylon folk guitars as opposed to classicals. If you're used to steel strings and it's a folk guitar and you have large enough hands, go for the 660mm. Apparently 666mm (includes compensation) is popular!
Post by DarwinStrings » Thu Jan 22, 2015 3:38 pm
Good memory Trevor. So you know I am not making a classical. I have a Fender template 2.3mm shy of 650 or a Banjo job at 665.2. High tension would be my choice but as the 650 is standard the Fender is also tempting.
Disclaimer. I never bought the banjo template, it came attached to the Stewy Mac Fender one.
RobDyball
Post by RobDyball » Thu Jan 22, 2015 3:43 pm
What scale do you use on the small-body classical Trevor?
Post by Trevor Gore » Thu Jan 22, 2015 5:13 pm
Rob, the one you played was 650mm, with high tension strings. That particular guitar doesn't need any more tension, but that model could be done in 660mm no problems, if someone prefers a longer scale.
Post by Nick » Fri Jan 23, 2015 5:47 am
DarwinStrings wrote:Disclaimer. I never bought the banjo template, it came attached to the Stewy Mac Fender one.
You say that like you're distancing yourself from your inner Banjo fetish? :lol: :lol:
Trevor Gore wrote:Apparently 666mm (includes compensation) is popular!
Be a devil of a thing to play! :lol: :lol:
Post by DarwinStrings » Fri Jan 23, 2015 12:28 pm
Damn was it that obvious Nick? I don't have much luck with banjos, the other day I had a customers one in the car and stopped at the shop. I was only away from the car for five minutes and by the time I got back someone had smashed a window and left another two banjos in there :(
Post by kiwigeo » Sat Jan 24, 2015 2:58 pm
DarwinStrings wrote:Damn was it that obvious Nick? I don't have much luck with banjos, the other day I had a customers one in the car and stopped at the shop. I was only away from the car for five minutes and by the time I got back someone had smashed a window and left another two banjos in there :(
I'd expect that in Darwin :shock:
Users browsing this forum: No registered users and 93 guests
