F Hole Binding Iron?
Jehu
Post by Jehu » Mon Apr 27, 2015 6:15 pm
Do any of you happen to have any experience making a small-radius bending iron for f-hole bindings? I tried making one using a length of aluminium pipe tonight. I was feeling quite proud of myself when I fired up the propane torch and almost immediately started to melt the iron. Like, within about 60 seconds, with the torch as low as it will go.
Any hot tips? Maybe trying to somehow have the smaller pipe extending from the inside of my larger pipe, so that the heat transfers to it without it being directly exposed to the flame?
Thanks!
Jay
edit -- sorry, I suppose this should be in 'Jigs & Fixtures'; mods feel free to relocate.
Re: F Hole Binding Iron?
Post by kiwigeo » Mon Apr 27, 2015 6:27 pm
Might be time to go electric. My bender has a small radius section for doing binding etc that bolts on top of the main iron.
Note that the radius of the pipe needs to be a bit tighter than the desired radius of the bend....dont ask me how I know this :?
Post by 56nortondomy » Mon Apr 27, 2015 6:53 pm
I use a little gas burner torch that i've had for years, it works well dosen't get too hot. I've also got a propane torch but i never use it, because that does get too hot. What about using some heavy gauge steel pipe, or take Martin's advice and go electric.
Jehu
Post by Jehu » Mon Apr 27, 2015 7:25 pm
I may eventually go electric, but it's just not feasible at the moment.
I wonder, would a decent ceramic curling iron get hot enough?
Post by Trevor Gore » Mon Apr 27, 2015 7:31 pm
Never tried it, but how about a soldering iron and a light dimmer?
(I use a 500W dimmer on two other bending irons, one heated by a tungsten linear flood light, the other by radiant heater elements)
Post by kiwigeo » Mon Apr 27, 2015 7:54 pm
Jehu wrote:I may eventually go electric, but it's just not feasible at the moment.
Well if you don't have any luck bending your F hole trim with the curling iron you can always cut your losses and do yourself a nice perm :mrgreen:
Post by Nick » Tue Apr 28, 2015 5:43 am
Trevor Gore wrote:Never tried it, but how about a soldering iron and a light dimmer?
I've used a soldering iron before Trevor with reasonable success, I bound some F holes on a thinline Tele before I had my current bending iron setup. Can't remember what Wattage the iron was but it must have been at the lower end of the scale as I never suffered any scorching.
Jehu
Post by Jehu » Tue Apr 28, 2015 1:00 pm
Interesting -- the soldering iron idea is definitely worth checking out. I would have never thought of that.
And thanks, Martin; very helpful. :D
jeff crisp
Post by jeff crisp » Tue Apr 28, 2015 2:03 pm
I once bent the sides for an archtop using an old soldering iron with a vacuum cleaner pipe over the top. I've also bent several sides with a heat gun placed at the end of a pipe. The skies the limit...or the fire brigade
sleake
Post by sleake » Tue Apr 28, 2015 7:09 pm
I use a paint stripping heat gun into steel pipe of various diameters. Distance, settings and on and off give pretty good temp control, and no flames to set fire to my beard - a vital consideration! :oops:
Woodsy23
Post by Woodsy23 » Wed Apr 29, 2015 12:30 pm
You could use a cartridge heater. There are available really cheaply on ebay, if you are prepared to wait. For example:
http://www.ebay.com.au/itm/10x100mm-220 ... 2a46fc08f5
You will need some type of temperature controller and would have to be comfortable working with electricity, hooking up and properly insulating the electrical wires.
I used one like this to make a bending iron, based on a method someone has described on the net. The cartridge heater is installed inside a larger steel tube and the space around the heater is packed with aluminium foil or similar to conduct the heat from the heater to the tube.
lucpet
Post by lucpet » Wed Apr 29, 2015 8:31 pm
"I have not failed 700 times. I have not failed once. I have succeeded in proving that those 700 ways will not work.
When I have eliminated the ways that will not work, I will find the way that will work." -Edison
Jehu
Post by Jehu » Thu Apr 30, 2015 1:16 pm
The cartridge heater looks like an interesting option for the future. I just bought a soldering iron and will try to track down a dimmer switch... we'll see how I go with that.
Thanks again, folks.
Users browsing this forum: No registered users and 110 guests
