Cleaning old grime off a fret board
trautsman
Post by trautsman » Fri Jun 19, 2015 8:43 pm
Just a question for the repairer/luthiers.What product do I use to clean 40 years of grime off a fret-board,I'm in New Zealand.
Sincerely
Trautsman
Re: Cleaning old grime off a fret board
Post by kiwigeo » Fri Jun 19, 2015 10:28 pm
trautsman wrote:Just a question for the repairer/luthiers.What product do I use to clean 40 years of grime off a fret-board,I'm in New Zealand.
Wipe with Shellite and if it's really tough gently scrape with a razor blade.
Post by jeffhigh » Sat Jun 20, 2015 9:17 am
A toothbrush with the shellite (naptha)can also help. Just don't plan on using it orally afterwards.
Post by Nick » Sat Jun 20, 2015 6:21 pm
On a rosewood fingerboard I use 0000 steel wool (in NZ, Briwax probably is the brand most available, places like bunnies, mitre 10 e.t.c) to initially loosen and clean the majority of crud off, then go in with the naptha/alcohol (I think Bunnings sell naptha/shellite under the 'Diggers' brand)and brush to get it out of the pores and corners between the fret and board. Then go back to the steel wool once clean, give the frets a good polish with it to remove any discolouration (oxidation) and then oil the fingerboard, should come up like new.
blackalex1952
Post by blackalex1952 » Mon Jun 22, 2015 6:59 pm
After the 0000 steel wool, I use a piece of leather to final polish the frets. The tongue from an old leather shoe is a good burnisher. Brings the wood up nicely too. Also good between string changes. I use the rough side first then the fine side. The rough side removes residues and the fine side for final polish. A bit like a leather strop.
hazboticus
Post by hazboticus » Wed Jul 29, 2015 11:46 am
That is....a really cool idea I am totally going to try out - :cl
demonx
Post by demonx » Wed Jul 29, 2015 12:49 pm
Razor blade to scrape the wood, steel wool the frets, then run a buffer over it.
Users browsing this forum: No registered users and 28 guests
