Thanks for any opinions on this!!
Rod I use epoxy on my fretboards in preference to HHG......I dont like using a glue that contains water on the fretboard.neck joint.rocket wrote:Just wondering if i should use HHG to glue my fretboard on to the neck that i've inserted two cf rods into and used epoxy, and now have two 4mm strips of epoxy surface along the glueing surface for my fretboard. Will the HHG adhere to the epoxy? and if it doesn't will it be a problem? should i just epoxy the f/b to the neck?
Thanks for any opinions on this!!![]()
The three main deciders on what glue I use:rocket wrote:Thanks Martin, in the past i've mostly used epoxy to glue my f/bs but was considering the HHG this time and thought i'd get some others opinions of it.
Cheers,,
Users browsing this forum: No registered users and 128 guests
