Electronic Tuners-what's on ur bench?
Hank
Post by Hank » Mon Oct 05, 2015 4:07 pm
Electronic Tuners, which one's are you guy's using and why?
I'm using the old Boss TU-2 which does the job, but i'm thinking of upgrading
maybe the Peterson Strobe iPad app?
any suggestions?
trade secrets welcome
Hank
Re: Electronic Tuners-what's on ur bench?
Post by Bob Connor » Mon Oct 05, 2015 4:38 pm
Peterson's good. I use the app on Android phone.
Hank
Post by Hank » Mon Oct 05, 2015 4:46 pm
Thanks for that Bob
I noted there seems to be a few add on apps, they worth it?
Post by kiwigeo » Mon Oct 05, 2015 5:35 pm
I use Windows version of Peterson tuner. I use it in conjunction with VA for tap testing work.
Are you just using the tuner for tuning or are you doing tap testing etc?
Post by Bob Connor » Mon Oct 05, 2015 6:39 pm
Hank wrote:Thanks for that Bob
The only add on I have is an adaptor lead that I can plug in to the phone.
I don't use it that much but I guess it's be more accurate.
Steve.Toscano
Post by Steve.Toscano » Mon Oct 05, 2015 8:03 pm
Tcelectronic polytune. Quick and super accurate.
I have 1 on the bench and 1 on my pedal board.
I never use the polyphonic function.
Post by Nick » Tue Oct 06, 2015 6:38 am
I have a cheap-arse generic clip on tuner (the little square ones) for initial stringing up then once I've got the strings to stop stretching, I switch over to the Peterson iStrobosoft app for final tuning and intonation setting.
old_picker
Post by old_picker » Tue Oct 06, 2015 4:02 pm
I use Korg rackmount tuners -an old one in the workshop in a loop between the bench and the amp - a newer version of the same one in the office. Both are quite accurate with a wide sweep and 3 tuning modes from coarse to strobe. For non amplified instruments i'll use a clip or if I am repositioning a saddle or bridge an old korg floor tuner sitting on the sound board.
I am thinking on getting a contact peizo so i can use rackmounts for acoustic instruments. I get the odd banjo, mando and a quite few non amped guitars. Rackmount tuners are apparently out of fashion and you can pick them up on evil bay quite cheaply when you consider what they do.
Users browsing this forum: No registered users and 163 guests
