manual fret slotting?
I'm just wondering what people's thoughts are on the 2 manual fret slotting systems from stewmac and LMII..
Lmi have dropped their price and its now about $175US which includes the template for slot positions..
The stewmac one is about $90US + $40US for the template...
anyone had any experience with these units ? they both look reasonable..is the quality of saw better in one ?
Other than a table saw method does anyone have any other methods they'd like to share.
cheers Grant.
cheers Grant.
Hi Grant,
My experience is with the Stew-Mac product which I find to be perfectly useable. The saw is especially good quality and the whole thing is a good system. I would say 15 minutes tops for a dread fingerboard. I have also made my own templates out of acrylic or perspex for scales that are not available in their templates . Their web site has a scale calculator on it to help with this. I got the whole uke family on one template, soprano and tenor on one side, baritone on the other. Hope this is helpful
Cheers John
Cheers John
Im hand cutting my fret slots using the LMI jig and Stewmac saws..works fine and the exercise is good for you.
One thing I do is run a bit of wax along the side of the saw to make it run a bit more freely.
Hi Jack,
I should have mentioned that my saw did not work too well until I removed all the lacquer coating on it with thinners, after that it performed nicely.
kind regards John
kind regards John
I bought a cheap little piece of crap GMC "table saw" from bunnies for $70. Yeah 70 bucks, so you can imagine how good it is as a table saw. I was kinda embarassed to ask for one, and had to put on a hat and some sunnies when I carried it out to the parking lot. They didn't have any plain brown wrappers for it. It looks like the GMC tile cutting saw.
Cobbled together with a fret slotting blade from Shane at High Mountain tonewoods and some blade stabilisers from Lee Valley, it works pretty good as a dedicated fret slotting rig. And considering the total cost was around $120, I'm happy with it.
I don't have any pics yet, and I don't see myself having time to take any in the short term (Craig knows just how busy I am at the moment). I will take some at some point tho.
Having slotted a few boards with this setup I can see a few areas that can be improved, so I'm going to rebuild it and post pix here once I'm done. It works well enough as it is - but I was never one to leave well enough alone
Way better than doing it by hand, and comparable in price to the manual rigs. But a bit more time spent on the initial set up.
- Dennis Leahy
I have had both the StewMac fretting saw and the LMI fretting saw. The LMI seems better made to me.
I'm about to make a new manual fret slotting jig, similar to my old one:
It's made with a pair of those furniture bolt/screws that are threaded for wood at one end and machine threads on the other.
The bolts support a piece of angled aluminum, and the top of the aluminum is radiused. There is a washer and nut below the aluminum as well as above it (on each side), so you can raise or lower the jig. The back of the backsaw rides the aluminum, to keep the depth of cut consistent, as well as radiused. So, the center of the radiused fingerboard has the same depth of fret kerf as the edges.
This one was fully manual - frets marked by hand and aligned by hand. The new one will use the LMI templates, and will have aluminum on both sides of the blade to stabilize the blade even more.
Oh, by the way, there are a couple of test cuts at the end of the pictured fretboard - not some kooky new scale I invented.
The circular saw blade on a tablesaw with a sled is a slick system, but the fingerboard does get kerfed more deeply than necessary. I'd go with the circular saw if I was making a lot of instruments, but for a slow poke like me, this is fast enough.
Another damn Yank!
I've had the L.M.I. jig for a few years now . As Dennis said , with a manual system ,there is one advantage in that the kerf can be cut to a matching radius very simply ,leaving more wood under the frets .
One thing to be careful of though is the width of the saw kerf. The L.M.I one looks to be an English "PAX" saw, and is advertised as having a kerf of .023"
After careful measurements , I have found this not to be the case. More like .021 " I discovered this after getting a fair amount of back bow when fretted. My fretwire had a tang width of .023 " . A lot of wire has a sliightly smaller tang ,so your fretting should be O.K. Just check the tang width first .
I informed L.M.I. of my measurements and typical of their great service ,they sent another saw ,,,,,,,,,same width of kerf ,so I'm guessing them all to be the same.
Removing the laquer and lubricating the saw are good tips from John and Martin.
Craig Lawrence
thanks for all the great info guys...
I will look into it.
Thanks for the offer Jack...I'll give you a buzz .
Dennis , that jig looks like it would work just as fine and looks easy enough to whip up...although I'm pretty jigged out at the moment...I feel I spend more time making jigs than working on the actual instrument..
cheers everyone.
cheers everyone.
- Dennis Leahy
Hi Lillian,Lillian wrote:Dennis, how did you radius the angled aluminum?
I printed out the correct radius arc from a cheap, er, inexpensive CAD program (DesignCAD), on heavy paper, cut it out with scissors, and transferred the line by scribing along the card stock with a fine point Sharpie marker. Then, I used a mill file on the aluminum, and it was easy to file that small arc.
The correct radius for the aluminum was calculated to get the fret saw teeth to cut a 16" radius. So, the aluminum was about 17.75" radius, if I remember correctly. Should be 17.625" for the new LMI saw.
This time, I found some T-shaped extruded aluminum, rather than the L-shape. That will allow me to keep plenty of aluminum in contact with the blade (on both sides) which should make it as accurate as anything out there. I need to grab a new saw from LMI as well - the newer ones cut on the pull stroke.
Grant, you're right, you could whip one up in a few minutes like my current one. I'm mainly starting over to make a new one wide enough to fit the LMI templates in, and thought of a couple of probably non-essential things I could do to improve it for longevity and accuracy.gratay wrote:Dennis , that jig looks like it would work just as fine and looks easy enough to whip up...
Another damn Yank!
I use the LMI jig. This thing will be around for hundreds of years, it is almost over built.
I cut a flat slot first on a flat fingerboard in the jig. Then I radius the FB and cut it to shape then go over the slots again out of the jig with a depth guide on the saw so I get a curved fret slot that follows the radius. Bit of extra work but it works for me and seems to give good results so far.
- Dave Anderson
Users browsing this forum: Google and 92 guests
