jerry need help = ..= about the heel~~~
jerryyanpu
Post by jerryyanpu » Fri Jul 01, 2016 5:33 pm
hi every one ~!
i got lots of help here! thanks !
there is a new problem~~
i bought a neck blank which is sapele ,35" quartersawn, however ,i found it is not enough for a whole neck including the head ,neck ,and heel in my classical guitar plan=..= casue it is not thick enough (23MM)。。。。then i found some austriaia blackwood ,the grain going well ,looks quiet dry...
so the question is , can i stack different wood to make the heel block? if it is ok ,what i need take care?
thanks everyone ~
Jerry Yan~
Re: jerry need help = ..= about the heel~~~
Post by kiwigeo » Sat Jul 02, 2016 10:12 am
I've stacked different woods on occasions...but you need to be aware of grain directions in the different pieces on the heel block. Sometimes you'll ended up with grain orientations that don't allow for easy working of the heel block with chisels and scrapers (ie youll get tear out in some of the layers of the stacked heel and not in others).
jerryyanpu
Post by jerryyanpu » Sat Jul 02, 2016 6:11 pm
kiwigeo wrote:I've stacked different woods on occasions...but you need to be aware of grain directions in the different pieces on the heel block. Sometimes you'll ended up with grain orientations that don't allow for easy working of the heel block with chisels and scrapers (ie youll get tear out in some of the layers of the stacked heel and not in others).
thanks for ur reply~!
yeah ,i have checked the grain directions,the piece of blackwood just like quartersawn ,so i stack it with the same grain directions of the sapele ,it is that work?
cheers ~!
jerry yan
Jeremy D
Post by Jeremy D » Sat Jul 02, 2016 8:09 pm
Did try stacking the sapele like the picture below?
Jeremy D
Post by kiwigeo » Sat Jul 02, 2016 8:16 pm
cheers ~!
jerry yan
Blackwood and sapele should go ok together and if all the wood is quarter sawn then you should be ok. Some of the mahoganies get a bit cranky with grain direction.
If youre going to glue on an end cap on the heel and youve got a mixture of light and dark coloured woods making up the heel block then think about how all the different layers will look together. I stack up the blocks and the end cap material and visually check how they look.....its purely asthetics but it's something I always think about at start of a build.
jerryyanpu
Post by jerryyanpu » Sun Jul 03, 2016 12:13 pm
Jeremy D wrote:Did try stacking the sapele like the picture below?
ty ,i tried it ,but still not enough.....this is why i consider use other wood= ..=
jerryyanpu
Post by jerryyanpu » Sun Jul 03, 2016 12:14 pm
cheers ~!
jerry yan
thank u very much ,u gave me lots of advices!!~~
mhunte12
Post by mhunte12 » Mon Jul 04, 2016 3:22 pm
Hi Jerry
I did this (through necessity) as the wood that I wanted to make my neck from (Tasmanian Black Hearted Sassafras & Yellow Box). I was very careful in making sure that the surfaces were very very flat before gluing, and that everything remained square when clamped up. Overall I was really happy with the outcome, and its been very stable so far. Good luck with your own project!
20 bits of wood in this photo (in hindsight, I could have got away with using 1 piece of Yellow Box down the centre):
Cut heel to template:
Roughly finished, ready to attach to neck and rasp to rough shape:
Test fit up, ready to rasp:
...and in various states of finish:
routout
Post by routout » Mon Jul 04, 2016 6:53 pm
That is awesome I like the effect it gives it will definitely suit the guitar . :)
