So far all is progressing slowly, but well, on the double bass build. The next step is to make a start on the neck. I have a board of Queensland Maple which I'm thinking of laminating together to get the right width. I might even put a 3mm veneer of blackwood through the middle. Should I use hide glue or Titebond for this? If hide glue is the go, then I may wait until spring when the weather (and the shed) will hopefully be a little warmer.
Cheers and thanks,
Michael
Laminating a board for a neck.
- hillbillybass
- Sassafras
Re: Laminating a board for a neck.
No cold creep with HHG, so that would be my choice.
- hillbillybass
- Sassafras
Thanks Allen, HHG it will be. Cheers.
Users browsing this forum: No registered users and 90 guests
