Ladder Braced Tenor Guitar
- Dave White
I love making instruments out of bits left over from other instruments. This is a little tenor guitar that I made as an experiment based on a Martin 5-15 using khaya (four piece top and back) with EI Rosewood binding and veneer, an ebony fingerboard and bridge and sycamore neck. Scale length is 597mm (23.5â€
Dave White
- Dave White
Colin,
Thanks. That's the first - and probably only - time that's happened to me.
Bob,
The top was around 2.5mm thick in the centre and around 2.2mm at the edges. I make thicker tops than most as that's where I think you get good trebles from. You can get bass many ways. I love hardwood topped instruments and will be interested to see yours progress.
Bob,
Dave White
- Ron Wisdom
- Taffy Evans
- Dave White
Ron,
Thanks - your building chops are coming along amazingly too. You should like tenor guitars as a lot of banjo players use them. I am just amazed how versatile ladder bracing is and now really firmly believe that the dominance of X bracing didn't replace an inferior system, but has in some ways stiffled the development potential of a whole new exciting sound area.
Kim (and Ron),
I don't know about the classic look - I'm just using Z-poxy and pre-cat lacquer - although this is a classic Martin size 5 body. Unusual fior me huh?. I like the sound you get using z-poxy as a layer rather than just in the pores on hardwood topped instruments - it gives a real bounce and projection to the sound. There is a very definite symbiotic relationship that the finish adds to bare wood in an instrument's tone and people who say that it just kills tone are missing a real trick.
Taffy,
Go for it - they are a blast to make and play. I have in mind a 5 string tenor (they've been done before by the way).
By the way. the tenor guitar will be making a transit vist on Monday and I hope to do some recording then.
Kim (and Ron),
Taffy,
Dave White
Users browsing this forum: TomBicknell and 94 guests
