Taylor "V Class"
Steve.Toscano
Taylor "V Class"
Post by Steve.Toscano » Mon Feb 05, 2018 12:04 pm
Because falcate bracing is too hard to do in a factory..... :P
https://reverb.com/news/taylor-reimagin ... _source=FB
Re: Taylor "V Class"
Post by Mark McLean » Tue Feb 06, 2018 6:01 am
Well they sure do make some amazing claims for the effects of this bracing system:
  • It apparently simultaneously increases both rigidity and flexibility.
  • It also improves intonation - "creates a more orderly response from the soundboard, improving the intonation by putting all the notes more in-tune with each other" (ah - so that is what intonation means - I always wondered)
  • "V-Class bracing makes the top more in tune with the vibrating strings. This eliminates much of the interference that causes some notes to waver and sound slightly out of tune. As a result, notes and chords played anywhere on the neck are more consistent and in tune with each other."
  • "Up and down the fretboard, the notes are full, true and consistent, with more harmonic agreement."
It seems to also whiten your teeth.....
In a couple of youtube videos I have seen the guitars do sound nice. But there is a lot of luthiery scientology going on here.
peter.coombe
Post by peter.coombe » Tue Feb 06, 2018 9:47 am
  • Because falcate bracing is too hard to do in a factory..... :P
Yep, that is exactly what I thought when I saw this.
Users browsing this forum: No registered users and 148 guests
