Carbon Fibre Thickness for Bridge
Mitch Lees
Post by Mitch Lees » Thu Aug 16, 2018 2:10 am
I am making a contemporary classical walnut bridge. I intend to use 2 layers of carbon fibre cloth which is .5mm thick - is this OK or does the cloth need to be thicker to give the correct amount of stiffness?
Assuming .5mm is OK - and the walnut slices are 2,3, and 4mm then the bridge blank will be 10mm - this is already one mm thicker than the blanks I normally use (9mm then reduced about a further 1mm when fitting to the dome of the top). If the blank were any thicker than 10mm it may result in the saddle not protruding enough.
Interestingly when studying the photo in Vol 2 (20-8) on page 20-5 it looks like the middle walnut slice is the thickest - not he bottom one. Is this just an illusion?
Grateful for advice please.
Mitch
Re: Carbon Fibre Thickness for Bridge
Post by Trevor Gore » Thu Aug 16, 2018 11:36 am
The CF cloth as spec'd in the book (198gm/m2) measures up at ~0.27mm thick. Works fine.
Check out the drawing on p 20-4, which gives finished dimensions. The CF thins out even further under clamping pressure.
Yes, but I see what you mean! Go with 4mm on the bottom so that you can sand the top curvature into it without getting the string holes too low.
